Re: Clarification help
The Solenoids requires its own special module and a breakout board same as the analog's if that could be the problem. You would attach power to it just like the analog through a WAGO connector on the breakout board to the power distribution board. Slot 8 is the farthest away from the cRIO LED indicators and ethernet ports. Can't give you the module's ID number right now, I would have to check my team's cRIO.
