Go to Post When you are able to get inside their heads, you will either... or.. B) Learn way to much, and end up running away screaming. - Either way, it'll be a learning experience. - Elgin Clock [more]
Unread 19-02-2011, 20:20
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
706 deploying minibot
Here's a video of our 2011 minibot deploy and climb.
Not the fastest bot yet.
KISS on the deploy.
http://www.youtube.com/watch?v=hvrbb9g9EHM
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 20-02-2011, 04:51
orisenak orisenak is offline
FRC #1056
orisenak can only hope to improve
Re: 706 deploying minibot
nice job!
check out our deploy/climb of ours!!
http://www.youtube.com/watch?v=aVMd8sCR7gA
-stuart kaneshiro
team 1056
Unread 20-02-2011, 08:00
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Please check the rules and the Q+A.
The minibot cannot be above the plane of the 18" line after it breaks the plane of the base of the tower. Hard to tell from your video about this.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 20-02-2011, 20:12
Bruceb's Avatar
Can you site a reference? I don't interpret it that way.
Bruce
Unread 20-02-2011, 20:39
nighterfighter nighterfighter is online now
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Bruce
Sure.
<G21>
HOSTBOTS may DEPLOY MINIBOTS only onto their ALLIANCE‟S TOWERS and entirely below the DEPLOYMENT LINE. Violation: RED CARD. TOWER is disabled if MINIBOT is DEPLOYED above the DEPLOYMENT LINE.
Unread 20-02-2011, 20:53
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Bruce
<G21> HOSTBOTS may DEPLOY MINIBOTS only onto their ALLIANCE‟S TOWERS and entirely
DEPLOYMENT LINE
DEPLOYMENT – the act of positioning a MINIBOT on a TOWER. DEPLOYMENT starts when the
MINIBOT breaks the vertical projection of the TOWER BASE circumference. DEPLOYMENT ends
when the HOSTBOT is no longer in contact with the MINIBOT. (Related form, DEPLOY, verb)
G21 Alone does not make your deployment illegal, however since deployment starts at the instance the Minibot breaks the tower perimeter, your deployment would be illegal, if at any point in your arc the minibot is above 18"
-Dustin Benedict
Unread 20-02-2011, 21:03
Bruceb's Avatar
Boy, read and reread that and still don't interpret it that way. No one at todays miny regional had any issue with it.
Bruce
Unread 20-02-2011, 21:10
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Draw a side view of the HOSTBOT and TOWER. Draw a horizontal line between them at 18" above the TOWER BASE. Draw a vertical line at the edge of the TOWER BASE. See if your any part of your MINIBOT is above the horizontal line, when it's on the TOWER side of the vertical line. If so, you're gonna get a RED CARD if an observant ref is watching.
Unread 20-02-2011, 21:11
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Bruce
Sorry.....
http://forums.usfirst.org/showthread...ighlight=plane
Unread 20-02-2011, 21:22
boomergeek's Avatar
boomergeek boomergeek is offline
AKA: Mr. D (Dick DiPasquale)
FRC #0241 (Pinkerton Robotics)
boomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant future
I don't necessarily read <G21> as prohibiting a host bot nor a minibot from breaking an imaginary plane at the height of deployment line as long as the hostbot nor the minibot is in contact with the pole.
Clearly, a host bot in contact with the pole above the deployment line, or a minibot in contact with the pole above the deployment line before the minibot has separated from the hostbot, are violations of one or more of:
<G20> ROBOTS/HOSTBOTS may not contact their own TOWERS above the DEPLOYMENT LINE. Violation: PENALTY for contact.
<G21> HOSTBOTS may DEPLOY MINIBOTS only onto their ALLIANCE‟S TOWERS and entirely below the DEPLOYMENT LINE. Violation: RED CARD. TOWER is disabled if MINIBOT is DEPLOYED above the DEPLOYMENT LINE.
<G22> HOSTBOTS may not contact their ALLIANCE‟S MINIBOT while any part of it is above the DEPLOYMENT LINE. Violation: TOWER is disabled
Chris Fultz interpretation "The minibot cannot be above the plane of the 18" line after it breaks the plane of the base of the tower." is just one potential interpretation of the rules. I would suggest Bruceb pose question to the GDC. BUT...
Correction (thanks Vikesrock): the GDC already ruled...and the vertically swinging minibot deployment in which the minbot breaks the deployment line imaginary cylinder is a violation.
http://forums.usfirst.org/member.php?u=33258
I think the deployment shown in the video meets the intended spirit of the rule and the field judges will have enough of a problem with monitoring for violation of <G21> when a pole contact is being made. I doubt most field judges would want to trust themselves to measure an imaginary cylinder at exactly 18". Will we see a special measuring tool?
Unread 20-02-2011, 21:30
MrForbes's Avatar
AKA: Jim
Perhaps the refs or inspectors can ask you to demonstrate that the MINIBOT is entirely below the horizontal plane after DEPLOYMENT...that should be possible before/after a match?
I'd like to see the alternative interpretation, how does it work?
Unread 20-02-2011, 21:33
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
SO do the rules mean that at no part of the minibot deployment(when your hostbot moves the minibot into position to climb) can your minibot be above 18in.?
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 20-02-2011, 21:35
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Post #8 in this thread by Squirrel does a great job of describing the rule as interpreted by the GDC in the Q&A
Unread 20-02-2011, 21:46
Bruceb's Avatar
Well, G21 says
G22 says
Deployment line is defined as
DEPLOYMENT LINE – located on the POST, approximately 18 inches above the top surface of the BASE.
LOCATED ON THE POST there is no reference to a plane here or anywhere. It is a line on the post so my interpretation is that your hostbot cannot touch the minibot while it is on the tower post above the DEPLOYMENT LINE.
THe deployment line does not exist anywhere but on the tower post.
Bruce
Unread 20-02-2011, 21:49
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Bruce, that unfortunately disagrees with what the GDC has ruled in the 2 Q&A posts I linked to. I would recommend posting your reasoning to the Q&A for additional clarification if you are hoping to stick with your current design.
