Go to Post It's super-ironic that a question about searching was found via searching. Whodathunk? - Brandon Martus [more]
Unread 20-02-2011, 21:08
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Re: Jaguar Issues...
seen this before! ..... we had the same problem last year while using a CAN bus and a Jag for position control on a swerve drive. You need to find a way to flatten the voltage spikes. What worked for us was to apply a 20msec rate limit to the position request to the Jag. As a back-up we came up with a function (tied to a joystick button) to save the encoder readings, disable the Jags, and re-enable them.
At what rate are you making the speed requests? The older IFI controllers ran at something close to 26msec.
Eric
Don't PANIC!
S. P. A. M.
