Go to Post Wait, I thought 2009 started on January 3rd... - ComradeNikolai [more]
Unread 20-02-2011, 21:15
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Help - Lubricant
You may use grease or other lubricants on the robot (not the minibot). Make sure that whatever you use will not contaminate the field or other robots.
The main relevant rule is <R31>
<R31> Lubricants may be used only to reduce friction within the ROBOT. Lubricants shall not be allowed to contaminate the FIELD or other ROBOTS.
Unread 20-02-2011, 21:23
Dante Serna3462 Dante Serna3462 is offline
FRC #3462
Dante Serna3462 is an unknown quantity at this point
Thanks! This info will help us a lot for sure. Good luck at the competition, hope you are doing well
Greetings:
Team 3462 & Mexico
