Go to Post Teams should make it a practice to protect their Victors (all the electronics, really) from the mechanical folks, with their saws and files and stone axes... - DonRotolo [more]
Unread 20-02-2011, 22:14
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Battery Chargers
Hello all, we are planning on getting more batteries and chargers.
originally we were going to get the charger from the KOP:
http://www.amazon.com/Schumacher-SC-...=pd_sim_auto_1
However i came across this one, http://www.amazon.com/gp/product/B00...Z769APCSGWAQ5V
Which does 2/8/12 AMP, instead the KOP which is 2/4/6.
Would charging at 12/8 amp do any harm to the battery?
I know the faster the charger the short the life but for competition we want to be able to run it at the fastest speed possible.
In short what is the largest possible AMPage we can charge the battery?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 20-02-2011, 22:21
xSAWxBLADEx's Avatar
xSAWxBLADEx xSAWxBLADEx is offline
DaBears til 13 turned Free Agent 14
AKA: Michael Hawley
no team (Free Agent)
Team Role: Scout
xSAWxBLADEx will become famous soon enoughxSAWxBLADEx will become famous soon enough
Send a message via MSN to xSAWxBLADEx
Re: Battery Chargers
idk what it would do to the battery, but it wouldnt be good we have about 6 batteries running off the KOP chargers, and at competition not 1 is below 90%, meaning one is 90% and all the rest are full of charge
2006-Palmetto Regional Champions with 11 and 1251 (MORT, TIGERS, BEARS, O MY!)
2007-Pittsburgh Regional Champions with 123 and 337 / Detroit Regional Champions with 123 and 903
2009-Traverse City District Competition Champions with 85 and 2645 / Traverse City District Competition Chairman's Award / Michigan State Championship Finalists with 1918 and 904 / Championship Finalist with 217 and 68
2013-Grand Blanc District Competition Champions with 33 and 1718
Unread 20-02-2011, 22:26
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Read the battery specs, max charge rate is 5.4 amps. so even the kit charger running at 6 amps is slightly pushing it.
http://www.mkbattery.com/images/ES17-12.pdf
Unread 20-02-2011, 22:29
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Absolutely DO NOT charge FRC batteries at a rate of greater than 6 amps. The batteries will be permanently damaged and may go into a severe failure mode while charging.
The max charge rate is 6 amps. The IDEAL charge rate for these batteries is 2 amps.
We use this charger. It charges 10 batteries at a time, at a sweet 2 amp rate. Keeps them in good shape.
http://batterytender.com/telecomm-st...12v-at-2a.html
You are much better off buying more batteries and charging them at the ideal rate rather than destroying batteries and creating safety hazards from ruptured batteries.
BTW - on a related subject everyone should replace the alligator clips on their chargers and use Anderson SB connectors to plug into the battery.
Yesterday I saw a team connect a charger with alligator clips into the SB50 connector, the clips touched each other, welded themselves together and turned WHITE HOT. It was an amazing site to see but this exercise is better left to Adam and Jamie on Mythbusters, not a FIRST pit.
Ed Barker
Unread 21-02-2011, 00:33
Mk.32's Avatar
AKA: Mark
K
6 amp MAX it is.
Thanks
Unread 21-02-2011, 00:58
Cascade Cascade is offline
Intermittent Mentor
Cascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to behold
This is last year's rule below (which seems to be missing this year)
<R41> An automatic battery charger rated for a maximum of 6 amperes must be used to charge the supplied batteries. When recharging the KOP batteries, either the charger provided by FIRST or an automatic charger with an equivalent charging current rating may be used.
I don't know if the rule changed this year or just an over site in the rules to date; however, since this is a safety thing, might just stay with last years rule until this is clarified.
Good luck to you
"Never quit, never give up, never say die!"
Unread 23-02-2011, 14:38
perlgerl perlgerl is offline
Michelle
FRC #0781 (Kinetic Knights)
perlgerl is just really niceperlgerl is just really niceperlgerl is just really niceperlgerl is just really nice
Our team has several chargers, but the one I prefer is a CTEK 3300.
From it's manual (pdf) ...
"The MULTI 3300 operates in a four step full
y automatic cycle. It starts the charging with an almost constant current (0.8A or 3.3A) until maximum voltage (14.4V or 14.7V) is reached. At this point the charger switches to constant voltage, and the current supply to the battery is gradually reduced. If the current drops to 0.4A, the charger switches to pulse maintenance. If the battery is charged and the terminal voltage of the battery falls to 12.9V, the charger automatically starts again at the first step of the charge characteristic."
Prior to buying the CTEK, our batteries were charged using the Schumacher SC-600A. Using the CTEK, we've discovered several "bad" batteries, with sulphated plates, that were not fully charging.
Unread 01-07-2011, 20:23
cadmanDOM910's Avatar
cadmanDOM910 cadmanDOM910 is offline
Foley Freeze 910 - Dom
AKA: Dominic Doxen
FRC #0910 (Foley Freeze)
Team Role: Student
cadmanDOM910 is an unknown quantity at this point
I know this is an older thread but it suits my question perfectly so I figured I would use it...
I am currently in the process of designing a battery cart for my team. One of my mentors suggested I look into a battery charger that could charge multiple batteries at once. Unfortunately I know nothing about electrical, so if someone could post some links to good chargers that could charge 9 to 12 batteries at once, it would be greatly appreciated.
Freeze Machine, Freeze Machine show me the Freeze you Freeze Machine!
Unread 01-07-2011, 22:34
Billfred's Avatar
Billfred Billfred is offline
After squeaking through Peachtree on one battery charger, we bought two of these at Walmart. Never had a problem with them through Palmetto and Championship--we annotated the icons with some labels to make it easy to glance at. We ran them at 6A during the competition day to ensure we always had one to run, then plugged up a battery to each to charge overnight at 2A.
Unread 02-07-2011, 09:25
DonRotolo's Avatar
Back to humble
FRC #0832
The insurmountable problem with charging multiple batteries at once is that each battery has slightly different needs at the moment, and using a single power source for charging fails to meet optimally the needs of any of those batteries.
In other words, each battery does best when connected to its own charger.
There ARE chargers that have several independent charging circuits (which I think is what you are seeking), I have seen them, just note that these tend to be quite costly. This one has 3 banks for $170, a 6-bank is $650+ (but at more than 6A, can't use it at competition), and for that money you can buy a lot of individual chargers like the one Billfred suggests above.
Unread 02-07-2011, 10:07
Billfred's Avatar
The other thing to consider: survivability. If one individual charger bites it during competition, odds are you'll be alright.
If your umpteen-bank charger goes down Saturday morning...
Unread 03-07-2011, 16:26
AKA: Dominic Doxen
Team Role: Student
Thanks for the advice! I think we decided on one 3 bank just to try it out and the rest will be the individual chargers billfred suggested along with the couple we already had at the shop. Thanks again!
Unread 05-07-2011, 01:28
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Reported.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 05-07-2011, 13:07
Jon Jack's Avatar
Jon Jack Jon Jack is online now
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
After reading about it in another thread, we gave the Auto Meter BusPro-600s a try. After running it for 2.5 years we love it.
It's a little on the expensive side, but it's been worth every penny. Some of the features we like the most are:
  • Removes sulfating automatically
  • Each battery is on its own charging circuit
  • Built-in float control so you can leave your batteries plugged in while in storage and not damage them
  • Built-in reverse polarity, short circuit and overload protection
Team 1538 / The Holy Cows, 2005-2016
Unread 05-07-2011, 22:29
Jon,
That is the one we use. Don, this charger is six independent chargers, one for each output. We had one output die on us last year, an open MOSFET. It was easily replaced and we are back in business. We replaced all of the gator clips with Anderson connectors. We also made a stand out of some 80/20 so we can set it up with the cables suspended.
