Go to Post Give yourself the best chance to win at the event you're at by picking the best possible alliance partners available - always. - Rich Kressly [more]
Unread 20-02-2011, 22:17
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Re: Fighting PID
Originally Posted by Geek 2.0 View Post
I'm actually in the process of doing that, and just found a strange problem...
I found this in the PIDController class in WPILibJ:
if (((m_totalError + m_error) * m_I < m_maximumOutput)
                        && ((m_totalError + m_error) * m_I > m_minimumOutput))
       m_totalError += m_error;
m_result = (m_P * m_error + m_I * m_totalError + m_D * (m_error - m_prevError));
m_prevError = m_error;
By the looks of it, it's saying that it won't add the error to the total error if the result would be outside the maximum and minimum output. Does that seem wrong to anyone else? Shouldn't it add the error no matter what, and then clip off the result to fit in the max and min output?
That is usually how it's done. There are a few things in WPI's implementation that don't make sense, but overall it's fairly useful.
In terms of your original question, even if you used WPI's implementation, your output doesn't have to feed straight into a motor. If you have them as separate outputs, then decide yourself how to feed them into the speed controllers, there shouldn't be any problem.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
