Go to Post The 2008 team is not the 2007 team and won't be the 2009 team. Every year is a new year and a new opportunity for growth and development as a FIRST team. It's very cool. - JaneYoung [more]
Unread 20-02-2011, 21:52
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
Fighting PID
I have yet to try this, but I'm curious...
I want to control the facing direction of the robot with a gyro and PID AND I want to control the travel direction of the robot with an accelerometer and PID.
Will these two PIDs fight each other? If so, how would I program around that? Also, what's a good way to program it, considering I can only use one pidWrite() function per class?
Unread 20-02-2011, 22:01
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Fighting PID
One solution:
Write a PID loop from scratch; it is a win win situation. You solve that problem, and you learn how to make a PID Loop and how it functions.
Unread 20-02-2011, 22:04
FRC #0107
Re: Fighting PID
I'm actually in the process of doing that, and just found a strange problem...
I found this in the PIDController class in WPILibJ:
if (((m_totalError + m_error) * m_I < m_maximumOutput)
                        && ((m_totalError + m_error) * m_I > m_minimumOutput))
       m_totalError += m_error;
m_result = (m_P * m_error + m_I * m_totalError + m_D * (m_error - m_prevError));
m_prevError = m_error;
By the looks of it, it's saying that it won't add the error to the total error if the result would be outside the maximum and minimum output. Does that seem wrong to anyone else? Shouldn't it add the error no matter what, and then clip off the result to fit in the max and min output?
Unread 20-02-2011, 22:17
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Re: Fighting PID
That is usually how it's done. There are a few things in WPI's implementation that don't make sense, but overall it's fairly useful.
In terms of your original question, even if you used WPI's implementation, your output doesn't have to feed straight into a motor. If you have them as separate outputs, then decide yourself how to feed them into the speed controllers, there shouldn't be any problem.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 20-02-2011, 22:31
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Re: Fighting PID
We've always written our own PID loops. I have never used the PIDs given to us, I find that if you make you're own you can customize it to what you need. It's not that difficult, I use Labview though.
Unread 20-02-2011, 22:42
Deetman Deetman is offline
AKA: Kevin Dieterle
Deetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond repute
Re: Fighting PID
I guess I'm a bit confused as to what you are using your sensors for. Using a PID with a gyroscope as feedback to control what direction your robot is definitely possible. As far as the accelerometer as a feedback sensor into a PID control loop, what exactly are you trying to control, direction of travel? Accelerometers pose an interesting control problem due to their sensitivity to noise including noise from vibrations in which a first robot has many. This can of course be overcome but I guess I'm confused as to what the accel will be helping control... Not saying you are wrong or that it won't work but to help you more I could use a bit more info.
FIRST Mid-Atlantic Volunteer (2012-present)
Team 1014 Alumni (2004-2005)
Team 1712 Mentor (2011-2015)
Unread 20-02-2011, 22:47
FRC #0107
Re: Fighting PID
I must say, I'm having a bit of trouble understanding what WPILibJ is doing. I'm trying to use it as a reference, but it's contradicting itself. Another example of something that doesn't make much sense:
if (m_continuous)
      if (Math.abs(m_error) > (m_maximumInput - m_minimumInput) / 2)
             if (m_error > 0)
                    m_error = m_error - m_maximumInput + m_minimumInput;
             else
                    m_error = m_error 	+ m_maximumInput - m_minimumInput;
Continuous means that we don't use maximum and minimum input values. but apparently if we're continuous, we're referencing maximum and minimum inputs values!!! What's going on now??
Maybe I shouldn't use this as a reference...
Unread 20-02-2011, 23:28
Alexander Meyer Alexander Meyer is offline
FRC #2358 (Bearbotics)
Alexander Meyer is on a distinguished road
Re: Fighting PID
Continuous mode still uses the min and max values, but not as limits--instead, it assumes that the shortest route to the setpoint can be achieved by going past the max back to the min and vice/versa. At least, if the comment on the SetContinuous method is to be believed..
Unread 20-02-2011, 23:42
FRC #0107
Re: Fighting PID
Wow, just wrote a lot of code (with no testing in between... this'll end poorly).
Thanks, that makes sense. Since I don't have that, I'm not supporting that feature. It all works out now.
Unread 20-02-2011, 23:49
Re: Fighting PID
Seems right to me.
No. You don't want the integrator error to continue winding up once it's large enough to produce the maximum output.
