Go to Post For any coaches weary of choosing human players this year because you're worried they might lose their cool mid-game, a good indicator of someones ability to keep focused is their attitude while playing video games. - BradMello [more]
Unread 20-02-2011, 21:35
Thundrio Thundrio is offline
Dedicated Racer
FRC #3673
Thundrio is on a distinguished road
our solenoids are not working.
we are using a double solenoid to control our claw, and it isnt working. i believe i have programmed it correctly but i wanted someone to double check.
here is my code. when i press button 5 it should extend the claw, and when i hit button 4 it should retract the claw. although nothing actuates, when i hit a button the corresponding side of the solenoid lights up.
thanks for help.
https://picasaweb.google.com/lh/phot...t=d irectlink
Interested in a new way of playing old games?
visit http://www.speedrunslive.com for a way to make single player games multiplayer!
visit http://www.zeldaspeedruns.com to open up a new world for zelda lovers!
pm me here or at zsr for more information!
Unread 20-02-2011, 22:34
Re: our solenoids are not working.
Your code looks okay, although the case statements are superfluous.
I assume the case statements just echo the button states in the False cases, too.
P.S.
Check the polarity of the solenoids connection to the solenoid breakout.
If the connector is reversed, the solenoid won't work as advertised.
Unread 20-02-2011, 22:53
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
thanks for help.
have you tried to manually activate the valves?
Do you see any indicator lights on either side?
Do you hear any clicking when you try and activate the valve?
Unread 20-02-2011, 23:01
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Allthough i dont really know how to program in labview nor really read labview code, i had this same problem yesterday at a scrimmage, What was wrong was that in our code we were calling for two seperate solenoids, but instead we were supposed to call for a single "doublesolenoid" and it worked after that, no we just hold down button "2" and our grabber is held open, even though this will be in java it might help.
if(leftStick.getRawButton(2))
Fluffy.feed();
grab.set(DoubleSolenoid.Value.kForward);
Fluffy.feed();
else
Fluffy.feed();
grab.set(DoubleSolenoid.Value.kReverse);
Fluffy.feed();
dont worry about "Fluffy" it is our watchdog and it needs to be fed more than normal for some reason.
Unread 21-02-2011, 02:00
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
Your code looks ok to me, just you don't need the case statements. If you are using 24v solenoids make sure your solenoid breakout is hooked up to 24v and not 12v.
