Go to Post Give me more tools; I’ll use the ones that are most useful for the job. - Natchez [more]
Unread 20-02-2011, 17:42
cruton55 cruton55 is offline
cruton55
AKA: Lindsey
FRC #3616 (Phenomena)
cruton55 is an unknown quantity at this point
Problem with KOP Photosensors
Is anyone else having trouble with their photosensors? Ours only want to work sometimes...
Unread 20-02-2011, 17:56
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Problem with KOP Photosensors
Nope. Ours detect the line rock solid.
What are you trying to detect, against what background? Do you know there is a sensitivity adjustment?
Unread 20-02-2011, 18:50
cruton55
AKA: Lindsey
one of our three sensors seems to be a bit glitchy, it works for atmost 20min then randomly it detects nothing. the other two sensors work fine though. The "tuneing knob" if you will has no effect on it almost as if the sensors become frozen. only after an extended period of time does it work again. any suggestions?
Unread 21-02-2011, 00:25
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
The tuning knobs might have broken off on the inside from turning it past the stop point. If you take the plastic bit off, there's a normal-looking trim pot in there, which you can adjust with a small philips head.
Make sure everyone knows not to turn the working ones past the stops.
Unread 21-02-2011, 00:26
Is your battery voltage dropping below the 10.4 volts required for proper operation of the photosensor? See Team Update #5 for an approved way to avoid this problem.
Unread 21-02-2011, 00:48
cruton55
AKA: Lindsey
Thanks to team 3238! were pretty sure we can fix them now and will try it first thing tomorrow
