Go to Post FIRST competitions ARE holidays, or they should be at least. - Kel D [more]
Unread 20-02-2011, 12:33
Jen19082010Capt Jen19082010Capt is offline
AKA: Jennifer
FRC #1908 (Shorebots)
Team Role: Electrical
Jen19082010Capt is an unknown quantity at this point
Send a message via AIM to Jen19082010Capt Send a message via Yahoo to Jen19082010Capt
Unhappy Rsl light problems
I have read every forum about the light, and my problem can't be solved by any of them. At first it didn't work at all, we tried rewiring it, we tried different lights, different side cars, and different connectors. Nothing worked. Then we found out that we could turn it on unplug both the light and the connector to the DSC wait a minute and plug them back in and it would work. Though it is not working right. It won't blink or anything. It just stays a solid orange no matter what we are actually doing.
Unread 20-02-2011, 12:42
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Rsl light problems
What is the small green LED on the Digital Side Car next to the RSL connector doing while the RSL is not working?
Unread 20-02-2011, 12:46
AKA: Jennifer
It is doing the same thing that the RSL light is doing, Staying completely solid. It used to blink before something went wrong with the light, now it does the same thing the light does. It won't turn on untill we do the one minute thing either.
Ps. Thank you for responding
Unread 20-02-2011, 12:54
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Does the green LED behave properly if the RSL is not plugged into the Sidecar? If not it won't matter what you do with the RSL itself you will get the same results.
Is the digital sidecar fully powered (all 3 lights solidly on)? Is the 37 pin cable firmly seated on both the cRIO module and the Digital Sidecar?
Unread 20-02-2011, 13:13
AKA: Jennifer
No the led light next to the RSL light does not turn on unless the light is working.
Yes all three lights are on and the cable is firmly secured.
Ps. Thank you
Last edited by Jen19082010Capt : 20-02-2011 at 13:18. Reason: needed to say thank you
Unread 20-02-2011, 13:24
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Alright, if the Sidecar is connected properly and the green LED doesn't behave without the RSL connected then there are two potential sources of the problem:
1. The cRIO
2. The Digital Sidecar itself
You have tried different sidecars so have you tried re-imaging the cRIO with the latest (v28) image?
Unread 20-02-2011, 13:38
AKA: Jennifer
The cRio has been re-imaged twice since the problem occurred
Ps. Thank you
Unread 20-02-2011, 13:42
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
I'm out of ideas then, hopefully somebody else will pop by to continue assisting you with the troubleshooting.
Unread 20-02-2011, 14:02
AKA: Jennifer
Thank you very much for trying to help me Team 1908 thanks you for the effort
Unread 20-02-2011, 14:08
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
If you haven't already, make sure the serial cable is SECURELY connected. If the problem persits, replace the cable. Common methods have already been mentioned.
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 20-02-2011, 14:17
AKA: Jennifer
Ok thank you alot, because you suggested to check the cable I did and we found out that the cable is not the problem, the part of the cRio that the cable plugs into is not making a proper connection. Any ideas on how to fix that.
Ps Thank YOU SO MUCH I COULD HUG YOU
Unread 21-02-2011, 01:12
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Do you mean the module? The blue piece with the silver sides that plugs into the CRIO itself? It should be plugged into the CRIO such that both of the metal sides are snapped in and flush with the walls of the CRIO. If they're not, push it in farther (but be careful).
Another thing that might be going wrong is if the module is plugged into the wrong slot. It MUST be plugged into slot 4 (counting from the part of the CRIO with the ethernet porst and such) or else the RSL will not work.
You could also try replacing the module (I believe the CRIO comes with two digital modules).
Did you say that the LED only flashes if the RSL is hooked up? That's bad, but I have no idea how to fix it (bar what's already been said in the thread).
Unread 21-02-2011, 09:03
AKA: Jennifer
It is in slot four, yes it is hooked up right. We are going to try replacing the module. I don't know how to bar what has already been said in the thread. Also Replacing the Module might fix that we will see and I will update this.
Unread 21-02-2011, 11:16
Use a strong light and good magnifier to check for any debris (especially metallic) in the cRIO's module connectors.
Unread 21-02-2011, 19:20
AKA: Jennifer
Thank you all we have gotten the problem fixed it was a really bad connection between the module and the cRio so we had to switch cRios to get it to work. Thank every team that helped us.
