Go to Post Every year I develop new connections and greater friendships with FIRSTers - and every year I am surprised to find just how many amazing people there are here. - MysterE [more]
Unread 19-02-2011, 22:54
pacerobotics pacerobotics is offline
FRC #3629
pacerobotics will become famous soon enoughpacerobotics will become famous soon enough
Re: Problem with wireless
This is sort off topic but does anyone know where I can get the power connectors for the window motors. Or will I have to make them? Plus (This is where I need a lot of responses) Is a victor or a jaguar recommended.
Unread 19-02-2011, 23:15
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
We bought connectors specifically intended for the window motors, but I have no idea where we got them. There have been reports of jaguars and window motors not mixing well, and admittedly we have had issues with our forklift motor, so I'd try the jags, but don't be surprised if you switch to a victor quickly.
As I understand it, if you don't need the anti-back drive functionality on the window motors (which we do, other wise our forklift would slowly come back to earth) you can remove the locking pins, a process which is described somewhere else. In theory, it will play more nicely with the jaguars then.
Unread 19-02-2011, 23:27
http://www.chiefdelphi.com/forums/sh...53&postcount=5
Unread 20-02-2011, 03:35
Blackphantom91's Avatar
Blackphantom91 Blackphantom91 is offline
Mentor + 4 = Stuck For Life
AKA: Malcolm Stirckland
FRC #1986 (Team Titanium)
Blackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura about
Mainly I think your should redo the setup because it sounds like something is going on in there. also your addressing on the computer from what I can tell its correct but just to be safe. also are you using a crossover or strait when connecting to the router. Im not sure if the Dlink has auto sensing where it doesnt matter but that also could be it.
[img*]http://i.imgur.com/Os2oTET.jpg[/img*]
Unread 20-02-2011, 20:51
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
So the order is this? > cRio-->dlink (new router)---->Classmate & driver station software?
That would mean that we have to use the computers wi-fi to connect to the dlink? And since classmate doesnt have the capabilities they have the new thing that they give at the competetion. So do we basically just follow the manual to install the new router and then go to the computers wireless communication and connect, without the gaming adapter?
"A team back in training !"
Unread 20-02-2011, 20:57
mattiej's Avatar
mattiej mattiej is offline
Programmer Guy
FRC #3413 (Mad Cows)
mattiej is an unknown quantity at this point
Kinda going back to the original topic, I think I have found the problem. When I tried pinging the cRIO, no response. Same when pinging the router. But when I checked the ipconfig on cmd, I found that my computer was using ipV6 by default on that connection, and it wasn't overriding with ipV4. I'm gonna check that tomorrow (kinda cutting it close) but I think that may be the solution.
Man pretending to be interested: "So how does this robot of yours work?"
Me tired of man pretending to be interested: "Magic. And Purple Yetis."
Unread 21-02-2011, 01:21
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Er, I think you're saying two different things here ("classmate doesn't have the capabilities... computer's wireless communication"), but to confirm, you use the classmate's built in wifi to connect to the dlink, and you also have your programming computer (if you have one) connect via wireless to the dlink. I'm not sure about the "new thing" at competition you're talking about... care to explain? Or have I not read the rules carefully enough
Unread 21-02-2011, 09:51
FRC #1514 (Vikings)
Originally Posted by WizenedEE View Post
You use the classmate's built in wifi to connect to the dlink, and you also have your programming computer (if you have one) connect via wireless to the dlink.
So the d-link is connected to the C-Rio, and the classmate we only use the wifi of it to connect? Not connect it to the gaming adapter that we had last year? And for that what would be the ips of the computer and the d-link? IS it this: 10.15.14.50 and 10.15.14.51?
This has been answered in other post by Mark but here it is:
At competition (not at home)...
You will take your DLink to a special WPA kiosk to make the event specific settings. These include setting the switch on the back to Bridge mode, resetting the DLink, hooking it up to the WPA kiosk, and the kiosk will supply a WPA security key unique to each team.
When you return home you will return your DLink to AP mode and remove the WPA security set at competition.
Last year's gaming adaptor is not legal for game play in 2011.
At the event for your match, you will plug your driver station laptop into an ethernet cable at the player station.
The Driver Station application will link up with the Field Management System (FMS), and through a VPN unique to your team the field router ill connect to your robot.
Unread 21-02-2011, 10:21
sometimestommy's Avatar
sometimestommy sometimestommy is offline
Schrödinger's Assistant
AKA: Thomas Moll
FRC #1939 (Ku-Nig-Its)
sometimestommy is on a distinguished road
Thanks, now i can drive it more than 5 feet!
