Go to Post Given a choice between giving a man a fish and teaching him to fish, you always want to teach them to fish. But sometimes that involves showing him how to put the worm on the hook first. - dlavery [more]
Unread 18-02-2011, 17:30
razorgator's Avatar
razorgator razorgator is offline
AKA: Chase Rainwater
FTC #9879 (Root Negative One)
razorgator will become famous soon enoughrazorgator will become famous soon enough
Digital Sidecar Relay Issue
We are having difficulty getting a Spike relay to work. The relay is plugged into Relay 7 on the Digital Sidecar. I have the sample Labview "Relay Example" code loaded on the cRio. Through the User Interface (again, from the standard LabView RelayExample project), I have Slot 4, Relay 7 and "Both directions" chosen as the DIO module, Relay Channel and Relay Direction. Our wiring matches these settings. Again, through the User Interface, I'm sending the "Forward" Relay Value. Unfortunately, the Spike Relay stays amber and none of the LEDs on the digital sidecar relay light up (either green or red).
Has anyone experienced a similar issue?
Thank you!
Unread 18-02-2011, 17:32
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Digital Sidecar Relay Issue
did you connect the power wires to the sidecar?
Unread 18-02-2011, 17:34
razorgator's Avatar
Yes, everything else plugged into the DS is working fine.
We have three photo resistors, a few Jaguars and a few servos. All of these work fine.
Thanks for the suggestion though.
Unread 20-02-2011, 20:04
tolefanjh tolefanjh is offline
FRC #1585
tolefanjh is an unknown quantity at this point
Have you found the solution to your problem? It seems we have the same issue and we're trying to solve it.
Unread 21-02-2011, 02:02
razorgator's Avatar
We replaced both the DS and the PWM cable connecting the DS to the relay. All is well now.
I hope you have the same luck!
Chase
