Go to Post Every team should have a rule about not shouting "ROBOT!" when transporting a robot around the pits/arena. - frasnow [more]
Unread 21-02-2011, 03:04
cRIO crashes when loading code
We're having a problem where 75% of the time that we try to load a program, it is unsuccessful because communication is reportedly lost. This is independent of programming computer, cRIO, loading method, and connection method (wireless/wired).
Initially I thought it was connection problems, however, after looking at netconsole, it looks like something on the cRIO is crashing. See the attached netconsole log.
I used the system manager when my program is running and it shows CPU load at approximately 95%. However, if I remember correctly, system manager has a decent amount of overhead, so the usage might be ok.
blem
I tried a few times with the no app switch set, and loading the software was always successful, however I haven't run it enough to be convinced that solves the problem.
