Go to Post A better way would be better..... - WizardOfAz [more]
Unread 21-02-2011, 07:16
java4first java4first is offline
(Java) Programming Mentor
AKA: Stu
FRC #0501 (Power Knights)
java4first is an unknown quantity at this point
Re: Dashboard Tutorial fro Java Pls :)
We started with the approach of using the LCD on the Driver Station by doing something similar, because we thought that was the best we were going to be able to accomplish.
But, if you look at my post to bascially the same question on "Info to Dashboard" started by sand500 (sorry, I don't know how to link here), then you'll see the information you need to get you into the 'real' Dashboard with LabView.
I know lots about Java programming, but our team had zero LabView experience, and we managed to make this work - so I'm sure you can too.
Good luck!
