Go to Post [Bring] programmers [to Championships], they may be small, quite and easy to miss while leaving for Atlanta but its hard to do anything robotic without them, I've tried. - Simon Strauss [more]
Unread 21-02-2011, 09:43
HarveyAce's Avatar
HarveyAce HarveyAce is offline
FRC #3329 (CAMBots)
HarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant future
Tam 3329 NEEDS YOUR HELP!
We are using window motors to articulate our arm, and we have a complication with the system. The arm goes in an almost full 360 degree motion, but with the gripper on the end, we cant get it to lift more than horizontal on either direction. it seems that we need a tension system to act as a counterbalance for the joint. would it be possible to use bungee cords? do they provide enough tension to help counteract some of the weight? we need this fixed today because tomorow is the ship day! this isnt good at all. the rest of the bot works great. ill post a pic on the portal of what we got. its team 3329. thanks!
"Though I fly through the Valley of Death I shall fear no evil, for I am at 80,000 feet and climbing."
Unread 21-02-2011, 09:52
Tarzan19 Tarzan19 is offline
President of Everything
AKA: Taran
FRC #2345 (Kearney Advancing Robotic Sciences (KARS))
Tarzan19 is a jewel in the roughTarzan19 is a jewel in the roughTarzan19 is a jewel in the rough
Re: Tam 3329 NEEDS YOUR HELP!
We suggest surgical tubing. Think about using a cam that tightens the tube as the arm moves down so it adds increasing tension on the tube and adds strength to the tube. good luck!
2010: Greater Kansas City Regional winners
2010: Greater Kansas City Coopertition Award Winners
Unread 21-02-2011, 09:53
arob9119's Avatar
arob9119 arob9119 is offline
Ninja Munkee!
AKA: Alex Roberts
FRC #2395 (Ninja Munkees!)
arob9119 is on a distinguished road
I would suggest using surgical tubing as a counterbalance. It usually works very well.
MUNKEES
(Misspelled on purpose)www.okcrobot.com
2012 Oklahoma Regional Winner
2012 Judges Award
Unread 21-02-2011, 10:01
Nick Bouressa Nick Bouressa is offline
Mechanical Lead
FRC #0166 (Chop Shop 166)
Nick Bouressa is an unknown quantity at this point
We had the exact same problem, we considered counter weights (but they obviously add weight) so we just replaced the window motor with a FP motor and it works fine.
Our team motto...
"THINK!, There must be a harder way!"
2011 GSR Chairmans winner
Unread 21-02-2011, 10:17
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
We had this problem on sat. so we tied surgical tubing on to it and it lifts with no problem now!
Unread 21-02-2011, 17:20
mspoerk mspoerk is offline
FRC #2062
mspoerk is an unknown quantity at this point
We've done something very similar with surgical tubing, and it works pretty good. If surgical tubing doesn't give you enough force, talk to your local dive shop about spear gun tubing. Similar to surgical tubing, but it has a greater force-stretch ratio, and doesn't seem to retain the stretch "memory" as much.
Unread 21-02-2011, 17:29
Chris is me's Avatar
AKA: Pinecone
Surgical tubing and or bungee cords (tubing is better because it's adjustable) work GREAT for arm counterbalancing. We successfully used it to make our arm work off of a single Window motor.
Unread 21-02-2011, 17:44
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
We had the exact same problem but the claw alone wieghed 9.2 lbs... so we decided to change it completely. Now it works GREAT!!!! the claw has only a back stop and a hook to grab the tube(made from U channel from the KOP chassis and IFI tred). before it was belts driven by window motors.
