Go to Post A good engineer will never stop learning. From his peers, technicians, and competitors. The field is just to vast for any one person to know it all. - Mr. Mike [more]
Unread 19-02-2011, 18:37
vesh7 vesh7 is offline
FRC #1768 (Nashoba Robotics)
Team Role: CAD
vesh7 is an unknown quantity at this point
Exclamation Flashing Fast Yellow Light on Grey Jag
We have a grey Jaguar which is flashing fast yellow. There is no information given about it as a condition in the manual. Does anyone have the same problem, a way to fix it, a way to set the jaguar's firmware to factory condition? Or is it a hardware problem?
Unread 19-02-2011, 18:50
BrandonG's Avatar
BrandonG BrandonG is offline
IRC Junkie
FRC #2865 (Roboteknix)
BrandonG is a glorious beacon of lightBrandonG is a glorious beacon of lightBrandonG is a glorious beacon of lightBrandonG is a glorious beacon of lightBrandonG is a glorious beacon of light
Re: Flashing Fast Yellow Light on Grey Jag
What steps have you taken to solve this problem?
www.roboteknix.com
Originally Posted by A bum in Atlanta
if you was my sister I'd mug you
If anyone uses IRC, pm me and let me know what networks, I have never heard of anyone in FRC using IRC besides me O_o
Unread 19-02-2011, 19:43
Team Role: CAD
It was a firmware problem.
Unread 20-02-2011, 07:24
MattCarey3625's Avatar
MattCarey3625 MattCarey3625 is offline
#3625 Programming and Wiring Head
FRC #3625 (Some Assembly Required)
MattCarey3625 is an unknown quantity at this point
If there is a program running check to make sure there isn't an output error. Else, check the battery. Good luck.
matt@hp-mini-110$> sudo make robot
sudo pass for matt:
unable to make robot
Unread 20-02-2011, 09:30
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Usually when this happens to us, it is a conflict with 2 Jaguars having the same ID on the network. I assume you are using CAN?
I'm right 90% of the time, so why worry about the other 3%?
Unread 21-02-2011, 10:46
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Fast flash yellow, like others have discovered, indicates that the Jag is in a "no ID" state. The Jaguar can have no ID when you try to assign and ID number that already exists on the bus. See the following example:
You start with IDs 11 and 12 on the bus and you add another new Jaguar. Now you have IDs 1, 11, and 12. You then want to assign a new ID to the new Jag, but accidentally try and assign 12 again. All the Jags go into the "I see you want to assign 12, should I take it?" mode, except for the Jag who's ID is already 12. This Jag sees the assign request and says "Oh no, there is about to be another 12 on the bus, I'm 12 too! I better forget my ID so there isn't a conflict." This Jag now forgets its ID.
A simple reset to factory defaults (power on the Jag with the user button depressed) will reset the no-ID Jag to ID 1, and you can then reassign a unique ID.
I understand the frustration on the sometimes patchy documentation. I just want to let you all know that we are listening, and are adding better documentation as quick as we can.
-David
