Go to Post What's a pirate's favorite robotics tournament? Aye-arrrrrrrrrr-aye, matey! - John Wanninger [more]
  #31   Spotlight this post!
Unread 20-02-2011, 12:30
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
Re: LogoMotion Learnings from Scrimmages
Are there any videos of these Scrimmages. 6 weeks of waiting to see a full match played, I don't really want to wait another 2. Also what were the average scores?
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
  #32   Spotlight this post!
Unread 20-02-2011, 12:40
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Originally Posted by MarcD79 View Post
As the rules state, the tube is measured at the smallest section & can be between 7-8 inches. We had the official "C" shaped template that slid over the tube as you inflate them. When the tube was inflated to make contact with the template, the inflation was completed. If the corners (triangle tube) appeared to be larger than the sides, that was considered acceptable.
That makes things even more interesting. Perhaps it is the FIRST spec that needs to change then.
I have no problem with the size of the tubes being different than what teams have been working with, the specs have been there the whole time. I do have a problem with tubes not fitting through the slots, that just doesn't make any sense.
  #33   Spotlight this post!
Unread 20-02-2011, 13:14
cdechant9's Avatar
cdechant9 cdechant9 is offline
FRC #1538 (The Holy Cows)
cdechant9 is an unknown quantity at this point
Exclamation Re: LogoMotion Learnings from Scrimmages
At the team San Diego pre-ship expo, we noticed it was nearly impossible to place over inflated tubes over uber tubes.
Over inflated tubes were ever easily knocked off.
  #34   Spotlight this post!
Unread 20-02-2011, 16:49
Andy A. Andy A. is offline
Getting old
FRC #0095
I have some videos of the matches played in New Hampshire. I still need to edit and upload. The camera I set up ended up getting mistakenly panned over at some point, so many matches only have one side of the field in frame. Better then nothing.
I'll post links when they're up.
Edit: here is the link for a few match videos. http://www.youtube.com/watch?v=o2hk6SWQfRw
  #35   Spotlight this post!
Unread 20-02-2011, 17:15
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
If I remember correctly, 2007 had a similar object, but it was pressure that was required so we barely used it.
I figure field reset will be told to inflate the tubes somewhere between the 7-8 inch thickness, or until the tubes are inflated to their shape and firm to the touch.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
  #36   Spotlight this post!
Unread 20-02-2011, 20:46
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
At Harvey Mudd:
I learned that my original design would have been very successful. Most teams could only do about one or two tubes per match. Might be because of the lack of power houses.
edit: I also learned that college has GREAT food... Just on the pricer side.
  #37   Spotlight this post!
Unread 20-02-2011, 21:03
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
we learned the hard way about the importance of having a digital sidecar free of metal shavings
  #38   Spotlight this post!
Unread 20-02-2011, 23:54
GCentola's Avatar
GCentola GCentola is offline
Strategical Tactitian
AKA: Garrick
no team (SparX)
GCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud of
Our team found that there is no rule for human interaction preventing the inflation or deflation of tubes. If a logo piece is overninflated and cannot fit, can it be deflated slightly by the feeder?
GO SparX on 3!!!!!
Check us out at:
http://www.gosparx.org
http://www.facebook.com/SparX1126
I Love Two Pencil Designs!
  #39   Spotlight this post!
Unread 21-02-2011, 00:02
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I love this place!
  #40   Spotlight this post!
Unread 21-02-2011, 11:04
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
We learned that at the Championship last year during the qual matches...
Thank-you 294 & 67
www.bobcatrobotics.org
  #41   Spotlight this post!
Unread 21-02-2011, 12:33
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
Did anyone's gripper, grabber, rollers ect get mangled during any of these matches? What about elevators?
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
  #42   Spotlight this post!
Unread 21-02-2011, 12:57
PaW's Avatar
PaW PaW is offline
AKA: Paul W
FRC #1899 (Saints Robotics)
PaW has a spectacular aura aboutPaW has a spectacular aura about
Not quite what you're asking ... but
At Skunkworks Practice Field (FRC 1983), I did see an elevator system almost "take out" the lowest peg. The horizontal crossbar of their mechanism, on the way down, slightly whacked the top of the lowest peg before the driver noticed. The driver re-elevated, backed up, then lowered their mechanism.
  #43   Spotlight this post!
Unread 21-02-2011, 13:12
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
176's gripper mechanism got whacked sideways as 88 was driving past us yesterday @ Suffield. It was purely accidental, as our operator should have folded our gripper inside the frame, but couldn't because of CAN errors.
Long story short, our bottom half of the gripper twisted sideways, and had to be unbent quite a bit before it could be used again.
We're lucky that the strike didn't effect the rest of the wrist, which in turn would have twisted our wrist gearbox, and probably pushed it off the linear slider on our elevator, making a huge, time consuming mess.
FRC 176 - Aces High - 09-12 - Student
FRC 229 - Division By Zero - 13-14 - "Mentor"
FRC 2170 - Titanium Tomahawks - 17-Now - Mentor
  #44   Spotlight this post!
Unread 21-02-2011, 13:15
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
What they are asking is did and endefectors or claws get destroyed in the heat of battle... Many teams were afraid to floor load because of the idea of it getting destroyed... From the matches I saw.. No... But a minibot took quite a beating
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
  #45   Spotlight this post!
Unread 21-02-2011, 13:52
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Wow, Human Players really do NOT know how to throw these tubes...
At both the Fembots and Poof/Space Cookies practice days, our HP was able throw tubes to our side of the field, sometimes all the way to the ZONE with a good roll. I wish our HP could take the other one's tubes...
A well made/positioned rolly grabber can pick up tubes no problem. We pick up tubes without a hitch. So much faster than driving cross field!
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
