Go to Post “There are two ways to compete, one is to drag your opponent down, the other is to raise the bar and excel. Which do you think is more beneficial to you in the long run?” -- John Abele - Candice.E [more]
Unread 21-02-2011, 11:32
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
line tracker calibration
Hi, can anyone tell me how to modify the 2011 kop line tracker to detect grey tape because I read a pdf file for it and im confused. As of now the line trackers starts as green then when I pass it over the reflective only, it turns orange and yellow.
Unread 21-02-2011, 11:39
Mandelbrot's Avatar
Mandelbrot Mandelbrot is offline
FRC #3007 (ROBOTITANS)
Mandelbrot is an unknown quantity at this point
Re: line tracker calibration
There is a little slot on each line sensor where you can insert a small screwdriver. Turn the screwdriver until the light just changes color, and then turn it back a bit so that when the sensor goes over the differently covered tape it will change.
Humans are like slinkies. Practically useless, but still fun to push down stairs.
Unread 21-02-2011, 16:36
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Refer to this thread.
http://chiefdelphi.com/forums/showthread.php?t=92140
