Go to Post Frankly, I love CD and everything it stands for. I've made more friends from this forum alone than I ever expected to meet in FIRST. I'd give just about anything to keep this system up, upgraded and going on long into the future. It's not even enough to show my thanks and gratitude. - BandChick [more]
Unread 21-02-2011, 11:43
vinnie's Avatar
vinnie vinnie is offline
FRC #3309 (Friarbots)
vinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond repute
Wifi Issues at Scrimmage
Our robot was having difficulty working with the FMS at our scrimmage yesterday. Communication was good, everything was pinging everything else, but our robot would never become enabled. It works perfectly with our routers so we cannot figure out what the problem was. The volunteers running the scrimmage didn't know what the problem was either because our robot connected to the FMS, it just wasn't being enabled. We tried using our DLink bridge and also a WRT54G that we have been using for the build season - both bridges connected perfectly. Any ideas on what the problem could be?
Unread 21-02-2011, 11:47
Rick Vogl's Avatar
Rick Vogl Rick Vogl is offline
FRC #0230 (Gaelhawks)
Rick Vogl is on a distinguished road
Re: Wifi Issues at Scrimmage
We had lots of problems as well. Reference this thread http://www.chiefdelphi.com/forums/sh...41#post1028041
Unread 21-02-2011, 17:43
On the DS diagnostics page, it lists the DS and cRIO versions. Can you report both of those?
Greg McKaskle
Unread 21-02-2011, 18:36
Rick Vogl's Avatar
cRio at v28. I don't know the DS version but a simple ping test didn't work. We have also tested with v25 through v28, same results.
With a borrowed cRio we are almost there, the DS->AP->BR communication works but not tothe cRio right away. Unplug the DS, plug it back in and we are fine.
Unread 21-02-2011, 20:49
The ring I ask is that the DS delivered at kickoff on the memory stick was released many months ago. Just prior to kickoff, the field, robot image, and DS were changed to introduce additional safety on the field.
So. If you have an issue with communications only on the field, this would be at the top of my list.
Greg McKaskle
