Re: Axis Camera 206 Problems
EDIT: We tested it out with a volt meter, and it holds steady at 5.2. EDIT: Alright, that's weird. It works when the back casing is off. EDIT: Alright, after some tweaking, it now works fine. As long as it doesn't move -__- RESOLVED: It was the power after all! While we were getting power through just fine, the original connecter it came with jiggled around. We replaced it with a new one, and it work well. Last edited by ArchVince : 21-02-2011 at 14:02. |
Hi
I have problems with the camera, i reset the camera, change the IP adress but don't show in the dashboard and i can't make the setup axis camera, show: Unable to complete operation because of unexpected error %d: %s59 TCP Open Connection in Axis Issue HTTP Request with Authentication.vi->Axis Issue Get.vi->Axis Create FRC User.vi->Dialog.vi can you help me? |
Did you follow the directions in the How to Configure your Camera document from the http://www.usfirst.org/frc/kitofparts web page? If those directions are what you can't make work, tell us exactly what steps you're taking and exactly where the results differ from what you expect. |
