Go to Post FIRST is not a "buy it and build it kit robot" competition. - sanddrag [more]
Unread 21-02-2011, 11:45
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
84" zone
We have a simple arm that just rotates on a single pivot that reaches the top peg, but in order to floor load we have to extend over the 84" mark when our arm is horizantal. Is it legal to extend over it for like .5 of a second or would we have to go into a 5 sec grace period?
Unread 21-02-2011, 12:11
DonRotolo's Avatar
Back to humble
FRC #0832
Re: 84" zone
No. If at any time your robot goes outside the boundaries of an 84" diameter right cylinder of infinite height it will be penalized.
And don't for a moment think that the inspectors won't mention to the referees on the field the fact that when your arm is horizontal it exceeds 84".
Unread 21-02-2011, 12:12
Tarzan19 Tarzan19 is offline
President of Everything
AKA: Taran
FRC #2345 (Kearney Advancing Robotic Sciences (KARS))
Tarzan19 is a jewel in the roughTarzan19 is a jewel in the roughTarzan19 is a jewel in the rough
Re: 84" zone
"<R11> During the MATCH, the ROBOT may not exceed the volume constraints of either STARTING or PLAYING CONFIGURATIONS (note: these limits are defined in reference to the ROBOT, not the FIELD)."
"Maximum
Horizontal Dimensions
84” (213.4cm) diameter vertical right cylindrical volume"
In my interpretation of the rules, i do not believe you will be allowed to exit the 84" cylinder at all.
if you have a problem with this ruling, you can always post a question to the GDC.
2010: Greater Kansas City Regional winners
2010: Greater Kansas City Coopertition Award Winners
Unread 21-02-2011, 12:18
2611.Shooter 2611.Shooter is offline
Programmer
AKA: Andrew Lavery
FRC #2611 (Vectors)
2611.Shooter is infamous around these parts2611.Shooter is infamous around these parts
Re: 84" zone
however, if you dont mind tipping your robot a bit... you can extend across the entire field. just expect to get yelled at.
Unread 21-02-2011, 12:53
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: 84" zone
I just want to expand on Don's Comment a bit, just in case other people come in with similar questions.
Usually, in years where there is a maximum size constraint, you will be asked during the inspection process if you can exceed this dimension, and will be tested to see if you can exceed this dimension. If you are able to expand beyond this dimension, the inspectors will usually note under what circumstances you can expand and pass this information onto the referees.
Personally, we can theoretically expand beyond 84" when our arm is parallel with the ground and our mini-bot deployment system is activated. Knowing this, we plan on implementing a software safety that prevents us from deploying our mini-bot while the arm is not in the home position. I would suggest that all other teams implement something similar to avoid unnecessary penalties.
-Dustin Benedict
