Go to Post it is not as hard as it looks, but thats prolly cause we havent tried to build it yet... - robolemur1236 [more]
Unread 21-02-2011, 11:54
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
LEDs connected to Solenoid Breakout. It's illegal, but why?
From the rules, it is illegal to connect anything but solenoids and the line sensors to the solenoid breakout. We have 3 LED strings, pulling about 300mA a piece. We would love to save some space and connect them to the solenoid breakout board, but guess what...
<R60> Solenoid Breakout outputs shall be connected to pneumatic valve solenoids or photoelectric sensors, PN 42EF-D1MNAK-A2, only. No other devices shall be connected to these outputs.
Any reason why custom circuits are not allowed? It's adding unnecessary complication to our already over complicated robot.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 21-02-2011, 12:07
DonRotolo's Avatar
Back to humble
FRC #0832
Re: LEDs connected to Solenoid Breakout. It's illegal, but why?
The only reason that matters is because it is in the rules. Same reason we're not allowed to use Duct Tape on the minibot.
I can speculate that they are concerned that teams will draw too much current from the breakout and make their pneumatics uncontrollable or erratic.
Side note: a 300 mA LED is about 1 watt. This will be BLINDINGLY bright.
Unread 21-02-2011, 12:30
RyanN's Avatar
RyanN
Yep, they're pretty bright all put together. I think there are about 30 LEDs in the string.
Controls Mentor
@rnazaretian
Previous teams:
Unread 21-02-2011, 13:17
The NI 9472 Digital Sourcing Module has protection against extreme overcurrent, so you probably wouln't be able to cause any fires, but the documentation warns that at currents between 1 and 13 amps the module "may be damaged".
Unread 21-02-2011, 14:38
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Believe me, my students were a bit ticked at this as well.
The solenoid breakout is simply the BEST way to power your LED light indicators.
Unfortunately, from my reading of the rules, that would be illegal.
I agree that we would all benefit from a loosening of the rules of what can be hooked up to the solenoid breakout to include custom circuits < 500mA.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 21-02-2011, 15:16
I believe the best way to handle this is to make the request in the Q&A.
The wording for the rule change that would allow this would be awkward, as the solenoid breakout can sometimes be used with the 24V rail. I would hope that the rule change would not allow using that rail for LEDs.
Unread 01-02-2012, 08:54
Bendito's Avatar
Bendito Bendito is offline
AKA: Benjamin LaRoche
FTC #7837 (The Thunder Colts)
Bendito is an unknown quantity at this point
Does this rule apply to the 2012 season, as I can't find anything that specifically prohibits the LEDs in this year's manual?
Unread 01-02-2012, 09:10
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I think the applicable rule this year is:
[R63]
Outputs from each Solenoid Breakout shall not cumulatively exceed 16W for the cRIO-FRC (8-slot) and 21W for the cRIO-FRC II (4-slot).
Unread 01-02-2012, 09:35
There are other ways to control LEDs that do not include the solenoid breakout. 300 ma is (As Alan has pointed out) excessive for the solenoid module. The manufacturer recommends 75 ma per output as a safe use of this module. It is for this reason that electric solenoid actuators or 10 watts or less can be driven from this module as well.
Unread 01-02-2012, 10:15
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
How about something like this...
<R60> Solenoid Breakout outputs shall be connected to pneumatic valve solenoids, photoelectric sensors, PN 42EF-D1MNAK-A2, or current limited, non-game related circuits only. For non-game related circuits, a total of 3 outputs may be used only for powering decorative lighting or sound circuits that do not contribute to the robots game playing capability. These optional circuits may only be connected to a 12 volt breakout board, (24 volt operation prohibited) and must include a fast acting current limiting fuse not to exceed 500ma. For ease of inspection, the fuse should be an inline fuse connected within 8 inches of the breakout board. No other devices shall be connected to these outputs.
Note: Because optional lighting devices are not game related, and are often custom, judges are provided wide leeway to disallow such circuits. Remember to keep these circuits simple, neat, and be prepared to provide additional documentation if requested.
This is the zeroth day of the rest of your life.
Unread 01-02-2012, 10:17
tsaska, that particular post was made for the 2011 season. See squirrel's post for the current rule.
Unread 01-02-2012, 10:19
I'm curious why you think a 300 ma led is excessive but an 800 ma solenoid is ok.
Unread 01-02-2012, 10:24
The datasheet for the Solenoid Breakout board specifies 750mA per output channel.
Unread 01-02-2012, 12:43
Sorry,
Left off the last zero. 750 ma at 12 volts is 9 watts.
Joe, I was considering the total for LEDs for three strings plus the loads likely for other devices as totaling more than one amp. As Alan reminded me last year the manufacturer has this rather odd table listing for trip modes. One of those lines for total current is this...
"1 to 6 A, Channel does not trip, Module may be damaged."
Unread 01-02-2012, 13:34
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
A Spike may be bulkier, but you could use one spike to switch two banks of LEDs by wiring each motor output to the positive side of the LED and running the common directly back to the PDB.
