Go to Post If there's one thing I've learned, it's that the robot is never truly finished. - Joseph Smith [more]
Unread 21-02-2011, 10:03
mama_tree's Avatar
mama_tree mama_tree is offline
FRC #3168 (WARRIORS)
mama_tree has a spectacular aura aboutmama_tree has a spectacular aura aboutmama_tree has a spectacular aura about
Switching from Jaguar to Victor
We are in the process of switching from using a jaguar to a victor for our window motor. Is there anything different that we need to do in our code other than changing the identifier?
We program in Java but this is the first time we have used a victor.
2010- Virginia Regional Rookie All Star
2010- Newton Division Highest Seeded Rookie Team
Unread 21-02-2011, 16:10
cybiko123's Avatar
cybiko123 cybiko123 is offline
Roving Mentor
no team (Illinois FIRST)
cybiko123 is an unknown quantity at this point
Re: Switching from Jaguar to Victor
You actually don't even need to change the identifier; you can leave it as Jaguar with no ill effects.
So to answer your question: Nope! Nothing needs to change.
Unread 21-02-2011, 16:19
I thought I read somewhere that the factory default null calibration is different for the Jags and the Vics. If you run a Vic and tell your software it's a Jag you might have some null offset issues.
Unread 21-02-2011, 16:48
cybiko123's Avatar
Roving Mentor
It's possible, but we ran our spin bar that way last year with no problem. YMMV.
Unread 21-02-2011, 16:50
A spin bar doesn't much care about null, does it ?
Unread 21-02-2011, 19:01
cybiko123's Avatar
Roving Mentor
True, true.
Unread 21-02-2011, 21:35
If you run a jaguar with the software set up for a victor, it will never reach full speed. If you run a victor with the software set up for a jaguar, it may respond erratically becasue it's being updated much faster then spec. It also will reach full speed prior to the full range of the software. There will also be a small null offset, but teams put up with that for years with the IFI controller.
