Go to Post Bottom line: hobbiests, hackers, and tinkerers can fiddle with something and make it work. Engineers are people who [b]engineer[/b] solutions to problems. - Dave Flowerday [more]
Unread 21-02-2011, 15:11
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: Ow! Metal Splinter...
I recently had an aluminum splinter stuck in my finger. This is what I did, please only use this process if you feel comfortable.
I used a tweezer and a needle. I used the needle to dig out some of the skins around the splinter, then used a tweezer to pull it out. It took a while and I had to dig in a little bit but it worked. Also, please burn the needle head for a bit before you use it.
Unread 21-02-2011, 16:26
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Have you tried Duct Tape? Put a small strip over it, and rip it off quickly. Repeat a few times, and it should be out. Works every time for me.
I'm right 90% of the time, so why worry about the other 3%?
Unread 21-02-2011, 16:41
WileyB-J's Avatar
WileyB-J WileyB-J is offline
4976 Georgetown Rebels
FRC #4976 (Rebels)
WileyB-J will become famous soon enoughWileyB-J will become famous soon enough
two credit cards on a 30 degree angle opposite each other pinching the skin containing the splinter does wonders in the back-country, might do the trick for you (i.e \./ )
Unread 21-02-2011, 18:34
RoboMom RoboMom is offline
people expediter on Team Kluge
AKA: Jenny Beatty, no relation
no team (they are all my teams)
RoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond repute
Years ago I got a metal splinter in a finger while sailing.
It didn't hurt. I carried on for 12 hours.
By the next day, my finger was twice the size, required a hospital visit for some pretty painful lancing and a long course of antibiotics.
You see where I'm headed with this.
Good luck.
Jenny, RN, MPH
Co-Founder of NEMO (Non-Engineering Mentor Organization) www.firstnemo.org
Volunteer Director, STEMaction, Inc. www.stemaction.org
FIRST Senior Mentor: Nov. 2004 to June 2009: "Experience is that marvelous thing that enables you to recognize a mistake when you make it again"
This is How I Work: http://www.chiefdelphi.com/media/papers/2862
Unread 21-02-2011, 18:42
MrEldritch MrEldritch is offline
FRC #0585
MrEldritch is an unknown quantity at this point
Our team solved the whole problem of metal splinters by building the whole robot out of fiberglass. Now we only have to deal with glass fibers, which are even more painful and harder to remove!
Unread 21-02-2011, 19:06
NullEntity's Avatar
NullEntity NullEntity is offline
AKA: Bryce
FRC #0093 (N.E.W. Apple Corps Robotics)
Team Role: Scout
NullEntity is an unknown quantity at this point
Anyone else reminded of Talladega Nights where he stabbed himself in the leg with a knife and uses another to try and pry it out?
FRC Team 93 Alumni
Unread 21-02-2011, 19:31
Chris is me's Avatar
AKA: Pinecone
Originally Posted by JesseK View Post
Oi, looks like a trip to the site's physician then. Thanks for the info!
Yes, do this.
If you do anything else, make sure what you're using is sterile in order to avoid infection.
Placing your finger in a very warm water bath to soak it will loosen up your skin for removal.
