Go to Post Welcome to CD! (just be careful..........it's addictive! :D ) - Jay H 237 [more]
Unread 21-02-2011, 15:37
Team 3657 Team 3657 is offline
FRC #3657
Team 3657 is an unknown quantity at this point
Need Help with Geting our robot to run
We have gotten our code to have no errors at all but when we deploy it and activate teleop the joysticks show that they are working, no errors come up but the robot doesn't respond, we have 4 drive motors and 2 window motors along with 4 solenoids. what shoud we do
Unread 21-02-2011, 15:40
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Re: Need Help with Geting our robot to run
Did u remember to plug it in...always the first thing that comes to mind. sometimes something isn't plugged in XD
Unread 21-02-2011, 15:41
FRC #3657
yes they are both pluged in
Unread 21-02-2011, 15:58
FRC #3657
Also it seems that when watching labview the teleop doesn't seem to run even though its turned on by the DS
Unread 21-02-2011, 16:00
What is the big orange Robot Signal Light on your robot doing?
What is the value of the battery voltage displayed on your Driver Station?
The Driver Station shows revision information for the DS and the cRIO. What are they?
Unread 21-02-2011, 16:42
FRC #3657
the signal light is blinking 9 times slow and 2 times fast, the battery is fresh off the charger
Unread 21-02-2011, 16:49
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
Are you positive everthing is wired into the Crio correctly. And have you edited the teleop or begin code at all, if so, i recomend taking the frc template unedited and download it to the robot, because just because there are no errors, does not mean you have the code written correctly. If it runs fine with the template code, then you will know it is your code. If it does not run, then it will have something to do with wiring, jaguars, or motors.
P.S. always iscolate the variables one by one to find the problem, then once you know what the problem is, you can solve it. Good luck.
in FIRST, it's process over product, and team over robot.
http://www.roguerobotsof4h.com/
Team 3585 Rogue Robots of 4-H
Unread 21-02-2011, 16:51
FRC #3657
how can i zoom out on labview so i can show u guys a full screen shot, and how do i take the screen shot
Unread 21-02-2011, 16:57
just copy the file that is stored on your c drive onto a thumb drive(DO NOT DRAG AND DROP!!! I MADE THIS MISTAKE AND LOST DATA AND HAD TO REDO THE WHOLE PROGRAM) and attach to a message.
Unread 21-02-2011, 17:04
FRC #3657
i found we are geting a watch dog error and ill upload my code in a few min
Unread 21-02-2011, 17:09
FRC #3657
heres some of the files ifu want to see more ask.
Unread 21-02-2011, 17:32
ummmmmmm, enlighten me on what you want the robot to do, because unless you want it to do something really complicated, you are doing way more work than you have to in begin vi and teleop vi, i did not look at autonomous because that won't affect teleop.
look at our program, it drives just fine and has a two motor arm.
and our teleop is in one of my recent posts, just find all my posts.
Unread 21-02-2011, 17:38
FRC #3657
it has 2 cylinders for en extending arm and claw drive motors and 2 window motors for the arm
Unread 21-02-2011, 17:43
would you like to talk on the phone briefly so we can clear this quicker.
FRC #3657
yes, Pm me ur #?
