Go to Post There's nothing wrong with taking suggestions but be sure not to let other people tell you how your team should be run. - NickE [more]
Unread 21-02-2011, 17:46
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
Re: Need Help with Geting our robot to run
will send in private message, one sec.
in FIRST, it's process over product, and team over robot.
http://www.roguerobotsof4h.com/
Team 3585 Rogue Robots of 4-H
Unread 21-02-2011, 22:04
Clayton Yocom's Avatar
Clayton Yocom Clayton Yocom is offline
Programming Mentor
FRC #0027 (RUSH)
Clayton Yocom will become famous soon enoughClayton Yocom will become famous soon enough
Send a message via AIM to Clayton Yocom Send a message via MSN to Clayton Yocom Send a message via Yahoo to Clayton Yocom
If you haven't had this figured out yet, I'd like to get some more information before I upload a slightly changed begin. Are you actually using Jags to run the left and right window motors? (as I presume what left and right is.) Also, are you actually using 4 solenoids? What I presume is your actually using 2 Dual Solenoids, so you can use the Dual Solenoid setting vs. the single and opening the Solenoids individually. I'm not sure what you were doing with the error out, as the normal error out *should* catch the errors that occur. The 20ms thing is also kind of confusing, so I'd like to understand better what you were doing there. Teleop looked pretty good for what you were doing in begin, as well as finish and disable.
Again, this is if you still couldn't clear stuff up in the call with Ian.
Unread 21-02-2011, 23:37
Originally Posted by Team 3657 View Post
the signal light is blinking 9 times slow and 2 times fast,...
A slow blink means the robot is still disabled. Fast blinks usually mean there is a loss of communication. Is the little green signal light on the Digital Sidecar doing the "2 times fast" blink as well? If the green light is continuing its slow blink and it's only the big amber light doing an occasional fast blink, you might not have the La/Lb jumper properly installed on the light (as specified in rule <R54> C).
Tell us exactly the steps you do in order to deploy the code and try to make it work. Include things like "Click the Cancel button" and "pull the left-hand joystick back." There might be something we'll notice that you need to do differently.
...the battery is fresh off the charger
That's not what I asked. Please answer the questions:
What is the value of the battery voltage displayed on your Driver Station?
The Driver Station shows revision information for the DS and the cRIO. What are they?
