Go to Post Re: New to programming, any tips? Join the mechanical team :) - IndySam [more]
Unread 21-02-2011, 18:10
hannah.rogue's Avatar
hannah.rogue hannah.rogue is offline
Hannah Circuitboard
FRC #3585 (Rogue Robots of 4H)
hannah.rogue is an unknown quantity at this point
Question Seeking veteran opinion on withholding robot components..
We are currently reconstructing our arm after an unfortunate (or fortunate?) decapitation at Saturday's scrimmage in Nashua and the team was wondering if it was worth withholding the arm and all the necessary components that fall in line to rewire and reprogram the entire arm?
Unread 21-02-2011, 18:18
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Seeking veteran opinion on withholding robot components..
Without more detail like pictures, I would say absolutely.
The big question is can you do it in the 30lb limit.
Unread 21-02-2011, 18:22
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Like IndySam said, it's definitely worth it.
Now, a more realistic question to ask is, can you do it with the time and resources allotted? And can you do it with the 30lb withholding limit?
If the answer to both of those questions is yes, then by all means, go for it.
-Dustin Benedict
Unread 21-02-2011, 18:27
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
We are doing that this year. We are keeping the arm and the electronics board. The pistons we ordered never came (coming this week) so we did not have a functioning arm. Code needs to written for it.
Unread 21-02-2011, 22:41
Jogo Jogo is offline
FRC #0353 (Pobots)
Jogo is on a distinguished road
@david-doesn't the electrical board not count towards 30lbs since it is entirely composed of cots?
Unread 21-02-2011, 23:00
The Lucas's Avatar
CaMOElot, it is a silly place
An electrical board is a FABRICATED ITEM as it has custom cut wires to components mounted on a custom cut board so it counts toward the weight. You could pull all the COTS components off the board and reassemble it at competition if you really need the components but can't afford the weight.
The OPERATOR CONSOLE is exempt from the weight by R33.
Robot Inspector
