Go to Post It's been said before--sports are fine and good, as long as you've got your priorities in the right order for you. - Billfred [more]
Unread 21-02-2011, 18:32
Becca334's Avatar
Becca334 Becca334 is offline
AKA: Rebecca
FRC #0334 (TechKnights)
Becca334 is a jewel in the roughBecca334 is a jewel in the roughBecca334 is a jewel in the roughBecca334 is a jewel in the rough
Question Axis Camera
For our camera, it is accepting images(working in the network) however we can not get the live feed to appear on the dashboard.
We set the username and password to FRC.
Any help to getting the Axis Camera working on the dashboard.
Thanks!
Unread 21-02-2011, 18:47
Bluedog24 Bluedog24 is offline
Head Programmer
AKA: Joey Ipock
FRC #1544 (One Byte Short)
Bluedog24 is an unknown quantity at this point
Re: Axis Camera
We left the username root and changed the pass to admin on our camera.
This was also added in the code.
AxisCamera camera = AxisCamera.getInstance();
Unread 22-02-2011, 08:08
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Re: Axis Camera
Originally Posted by Robby Unruh View Post
Be sure to run the AxisCamera Setup Utility on the desktop. Ours didn't work until we used that tool, either.
From this thread: http://www.chiefdelphi.com/forums/sh...ad.php?t=92576
I suppose FIRST just kind of expected teams to run that tool. But don't worry, you're pretty much in the same boat as us. We only recently figured it out. No one on CD seems to point it out that often...
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 24-02-2011, 07:34
OJ_Helms OJ_Helms is offline
FRC #3011
OJ_Helms is an unknown quantity at this point
Re: Axis Camera
Reset your camera. In order to get an image onto the driverstation through a connection through the cRIO, the camera must have its default ip of 192.168.0.90.
I had the longest trouble with this because I had set my camera to 10.30.11.15 (which is used to bypass the cRIO but no image processing capabilities.)
