Go to Post ...if you say "AndyMark" three times we show up... - Billfred [more]
Unread 21-02-2011, 18:33
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Wheel base and Pneumatic tires
You may want to put lower-traction wheels on one or both ends. That helped a 6WD deal with turning issues.
Our bot was back side heavy with the 6 wheel configuration (it worked fine on concrete, but carpet was a killer). We could not turn during the scrimmage. So we replaced the back wheels with the smooth plastic ones, it was a thing of beauty.
