Go to Post There are no simple solutions, as every solution has its own problems. - M. Lillis [more]
Unread 05-02-2011, 15:55
Kevin Wang's Avatar
Kevin Wang Kevin Wang is offline
Software Engineer, Webmaster
FRC #0694 (StuyPulse)
Kevin Wang is an unknown quantity at this point
Incorrect voltage readout on Driver Station
Whenever we are connected to the robot, the driver station always reports a voltage of 17.68 volts. This issue has been observed on multiple laptops. Has anyone else observed this issue?
Unread 05-02-2011, 16:34
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Re: Incorrect voltage readout on Driver Station
Just thought I'd add to the problem:
We always get somewhere between .05-.07 volts
This happened like 3 or 4 days after the switch to SmartDashboard
Unread 09-02-2011, 10:44
What programming language are you using?
Is the battery monitoring jumper installed on the analog breakout?
Unread 09-02-2011, 11:48
The NI 9201 analog input module is only supposed to be capable of reading a maximum of ten volts. The Analog Breakout has a 680ohm/1k voltage divider in the circuit to reduce the battery voltage to something within range. The calculation of the number to display compensates for this. If somehow you're getting full battery voltage on the NI 9201 input, and if it is somehow returning that value (which is greater than it is specified to handle), you'd see about 17.68 volts on the display. An open circuit in the 1k resistor path would do it.
Your team probably has a spare Analog Breakout (one came in the kit this year and last year, and there were two with the first year's cRIO). Try swapping out the one you're using now and see if the voltage display becomes correct.
Unread 09-02-2011, 13:03
LV1601's Avatar
LV1601 LV1601 is offline
FRC #1601
LV1601 is an unknown quantity at this point
This happened to us before just try to install the jumper again if it not perfect then it might read wrong.
Unread 09-02-2011, 22:06
FRC #1747
No idea what the heck happened, but our bot hit a locker (don't worry the bumpers were on) and it started magically working
I guess the impact somehow fixed the wiring
Unread 20-02-2011, 08:49
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Exclamation Re: Incorrect voltage readout on Driver Station
Another thing to add that issue our driver station always reads 0 voltages whenever we are connected to robot.
Does someone know how to fix this problem?
Unread 20-02-2011, 09:11
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Common causes of this are not installing the jumper on the Analog Breakout and not powering the Analog Breakout board.
The jumper should be installed on the outside two pins of the 3 pin header.
The Analog Breakout requires 12V power from the Power Distribution board in order to run.
The Analog Breakout Datasheet provides more detail if you need it:
http://www.usfirst.org/uploadedFiles...out%281%29.pdf
Unread 21-02-2011, 14:01
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Ours is reading zero also. I have swapped analog modules and breakouts and the jumper is in the correct position. We are playing with custom dashboard code at the moment and getting message errors. Could that be messing it up?
TIA
Unread 21-02-2011, 14:32
...our driver station always reads 0 voltages...
It would greatly help us help you if you could take a clear photo of your analog breakout while the problem is occurring and post it here, showing the jumper and the wiring connected to it.
Unread 21-02-2011, 15:57
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
photo attached - sure looks correct
Unread 21-02-2011, 16:11
It looks okay...except for the lack of any indication that there is actually power applied. There's a green LED that ought to be lit. What voltage do you see using a meter on the white Wago connector?
Unread 21-02-2011, 16:20
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Sorry - the power was not on - the green LED is on when power is applied - we see 12.07V on the wago connector. It must have something to do with the dashboard packet format not matching (because we are customizing it).
TIA
Unread 21-02-2011, 17:45
Customizing a dashboard will not break the robot battery voltage communications. They are very independent.
Greg McKaskle
Unread 21-02-2011, 23:21
The problem became obvious once I realized what to look for.
Keith, your NI 9201 module is in Slot 8 of the cRIO chassis. It needs to be in Slot 1, at the end nearest the Ethernet ports and power connector.
