Go to Post Whatever the rule, MAKE IT CLEAR. - Bill Beatty [more]
Unread 21-02-2011, 20:35
geel9 geel9 is offline
FRC #1317
geel9 is an unknown quantity at this point
Limit switch returns true always
I hook up the limit switch, assign the correct channel and refnum name and whatnot. The classmate detects and updates the switch on its LED indicators, yet my code always sees it as true.
Unread 22-02-2011, 00:05
Re: Limit switch returns true always
It's obviously wired properly. Let's see your program so we can help you find where the code might need to be fixed.
