Go to Post Robot: Gyro, please reset yourself and verify proper operation. Gyro: ... WHY IS THE EVERYTHING SPINNING SO FAST? HELP! ... Robot: Are you working yet? How about now? - EricVanWyk [more]
Unread 22-02-2011, 01:16
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: Incorrect voltage readout on Driver Station
Originally Posted by Alan Anderson View Post
The problem became obvious once I realized what to look for.
Keith, your NI 9201 module is in Slot 8 of the cRIO chassis. It needs to be in Slot 1, at the end nearest the Ethernet ports and power connector.
Hmmm - I'll check it tomorrow. I thought it was in slot 1.
Thanks
Unread 22-02-2011, 17:50
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Thanks Alan - the students swapped the cRio mount around and I did not even notice - an acute case of cRio slot dyslexia!!
All is good now!
