Go to Post Make other plans. No mass-produced food at an arena is ever going to be good. - sanddrag [more]
Unread 21-02-2011, 22:14
orisenak orisenak is offline
FRC #1056
orisenak can only hope to improve
Does a ubertube score count if you are touching it at the end of autonomous???
Thanks
Unread 21-02-2011, 22:53
Tyler Hicks's Avatar
Tyler Hicks Tyler Hicks is offline
NC Gears
FRC #1918 (NC Gears)
Tyler Hicks has a spectacular aura aboutTyler Hicks has a spectacular aura aboutTyler Hicks has a spectacular aura about
Re: Does a ubertube score count if you are touching it at the end of autonomous???
I believe the tube must be hanging independently on the peg for it to count.
2010
2011
2006-Pres.
Unread 22-02-2011, 00:35
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
From several interpretations, the consensus is that if the peg is keeping the UBERTUBE where it is (as apposed to your manipulator holding it in place), then it is considered HANGING. If not, it is not considered HANGING, and therefore does not count.
Basically, as long as your manipulator isn't the thing holding it in place, and the peg is, you're good.
As an aside on the specific legality of the rules, I would try to get away from your scoring rack during Auto, just in case the refs are sticklers about manipulator contact after auto. Ours is (currently) set up to do such a thing.
Edit: it's midnight, I could really care less if I repeat myself, but I have a sneaking suspicion that this will be a major hubub at Regionals, and therefore would like to see as many interpretations as possible, so teams can understand.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 22-02-2011, 08:55
GaryVoshol's Avatar
Cogito ergo arbitro
Simply look at the definition of HANGING:
HANGING – a GAME PIECE is HANGING when it is fully supported by a PEG through its center hole and released by the POSSESSING ROBOT. If a GAME PIECE on the floor is preventing a GAME PIECE that has been hung on a bottom PEG from becoming fully supported (that is, if the floor GAME PIECE was not there, the hung GAME PIECE would be scored) then that GAME PIECE will still be counted as scored.
It says a GAME PIECE must be fully supported on the PEG and must be released - no longer in POSSESSION. It doesn't say anything about touching.
Don't make it hard on yourself and don't give the referees opportunity to say it was not released - make it obvious it was released if at all possible.
(since 2004)
