Go to Post Please forgive any possible profound language. - PortugazD.Ace [more]
Unread 22-02-2011, 09:01
kawalla kawalla is offline
Rookie Year: 1900
kawalla is an unknown quantity at this point
How do I reimage a crio
I'm new and our head programmer (only guy who knows how to do this (re-image the crio)) isn't here
and we have a problem where we need to re-image our crio after every time we turn it off for an extended period of time
apparently this isn't that big of a deal except for the fact that no one knows how to re-image it
could anyone tell me how to re-image a crio
Unread 22-02-2011, 09:06
aechmtwash11 aechmtwash11 is offline
FRC #2783
aechmtwash11 is an unknown quantity at this point
Re: How do I reimage a crio
connect a laptop that has the NI FRC C-Rio Imaging Tool to the c-rio port one with an ethernet cable.
Select the newest image
Select Programming type/Other options
Enter Team number
Hit re-image
(haven't done this in a while, but this should be close to what you have to do)
Unread 22-02-2011, 09:57
Blackphantom91's Avatar
Blackphantom91 Blackphantom91 is offline
Mentor + 4 = Stuck For Life
AKA: Malcolm Stirckland
FRC #1986 (Team Titanium)
Blackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura about
All the documentation you should need is here also you will have to download the new images in the updates that came out on the Feb.20th, Good luck!
http://usfirst.org/uploadedFiles/Rob...cRIO_Rev_A.pdf
Updates you need to re-image to the current image. (Without these you will not be able to run in competition.) I believe that the new version is v28
http://usfirst.org/roboticsprograms/....aspx?id=18758
[img*]http://i.imgur.com/Os2oTET.jpg[/img*]
Unread 22-02-2011, 10:23
2829ron 2829ron is offline
FRC #2829
2829ron will become famous soon enough2829ron will become famous soon enough
I think what you are wanting to do (assuming you have the newest image on the crio) is have your code run at start up. To do this you open your project, go down to build specifications (in project explorer, expand RT CompactRIO Target, Should be at the bottom of the project explorer), left click on build specifications, right click on FRC Robot Boot-up Deployment, select build. After it has built, connect to ethernet port one on the crio, left click build specifications, right click FRC Robot Boot-up Deployment, select run as start up. This should make your robot code stay on the crio.
David
