Go to Post Leave it to Cheif Delphi to make a thread go from discussing the imminent game hint to discussing what is the superior pizza topping. - BriteBacon [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 21-02-2011, 16:19
DesignFlaw06 DesignFlaw06 is offline
DesignFlaw06 is an unknown quantity at this point
BDC-Comm "Gate Fault"
We decided to use CAN this year, using the RS-232 to CAN bridge inside the Black Jaguar. Had it working just fine earlier in the season. Of course it gets close to ship date, and now we can't get it working.
Using BDC-Comm, we get a red rectangle that says GATE FAULT in the upper right corner on two of the jags (we've got a total of six, and the other four run perfectly). We've tried each Jaguar individually, different computers, new cables, different configurations, etc and can't get anything to work consistently.
On Jag #2, we get the gate fault only when trying to drive the motor with a positive voltage value, it'll go the opposite way all day, but as soon as we try to go the other direction, it stops and we get a gate fault. Jag #5 gives the gate fault error as soon as we choose that Jag from the drop down list, although the error will occasionally timeout long enough for the wheel to spin for a second or two.
Any help would be greatly appreciated. Thanks!
Unread 21-02-2011, 23:34
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: BDC-Comm "Gate Fault"
That fault means there's a hardware issue: your "gate" is bad.
I don't know if this refers to your MOSFET driver, or the MOSFETs themselves.
I do know that you can RMA that Jaguar and get a replacement. Hopefully your competition is not week 1.
-- Marshal Horn
Unread 22-02-2011, 09:52
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Are gate faulting ones Grey Jags, Black Jags or both?
Unread 22-02-2011, 11:32
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
We had the exact same problem with both of our black jags from the KOP, except that the first one that had a 'gate fault' completely failed shortly after and our other one doesn't go in either direction. Fortunately the serial to CAN bridge still works, otherwise we wouldn't be able to do anything. It sounds like NI had a batch of faulty MOSFETs that they put in our jags.
Jason
Unread 11-03-2011, 15:54
rarzone's Avatar
rarzone rarzone is offline
FRC #2813 (Gear Heads)
rarzone is an unknown quantity at this point
We have also had a Gate Fault and were not using the CAN bus. After RMA, TI has had us confirming fault and is at the point of stating that a "user fault" is responsible...becoming frustrated, also.
Unread 11-03-2011, 19:35
Have you tried resetting the jaguar? That fixed one of our jaguars. You can reset it by holding down the User button as you power on the jaguar.
Jason
