Go to Post Based on EXTENSIVE analysis of this image, I have concluded that we will have to use wires on our robots. I am certain of it. - theCADguy [more]
Unread 22-02-2011, 11:29
Banebots P60 256:1 output shaft free play
Does anyone know what a reasonable range is for the angular free play of the output shaft of a Banebots P60 256:1 gearbox?
I've got one here that has 15 degrees free play, and I'm wondering if that is a sign of damage and/or impending failure.
Unread 22-02-2011, 11:41
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Re: Banebots P60 256:1 output shaft free play
Sounds like where the dog features engage between shaft and first planetary set are rounding off. That's what ours did (along with the tube turning and rolling the pins off the flats) and then the whole feature twisted off. I think the 35 ft lb max limit on those is pushing it, and you need to consider shock loads beyond that limit if it can happen in your design.
www.179swampthing.org
Unread 22-02-2011, 11:42
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Remove gearbox, disassemble, take pictures, post pictures.
There's plenty of time.....
Unread 22-02-2011, 13:59
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Uh uh...Fed Ex will be picking ours up by 2:30...it was crated at 9:30 this morning and I am NOT taking it out no matter how much the children beg and sit on the crate!
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 22-02-2011, 15:29
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
In ours there was no free play when new. I would suspect the Double-D shaped end of the shaft is rounding out in the plate (I am correct in saying these are driven like that right?). It may yield until some point and then not go any further. If you have that much free play though, I'd suspect it would keep opening up. Hard to say.
Unread 27-02-2011, 18:01
Swampdude's Avatar
AKA: Dan Quiggle
Unread 27-02-2011, 18:11
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Banebots P60 256:1 output shaft free play
It will continue to open up. If you are using it for an arm, it is likely being overloaded, especially if quickly reversing direction. We have doubled up these transmissions on the arm shoulder, and have eperienced similar results, but not failure. TIG welding the shaft to the output plate by an experenced welder has been done in the past.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 27-02-2011, 18:12
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
I ran into a similar failure mode with my P60 256:1. I think it resulted from applying a large amount of torque on the output shaft (trying to backdrive an arm) while the friction inside the gearbox caused the shaft to not rotate, thus causing the little pins to sheer the ringgear.
If you're in a pinch to repair it, I believe you can weld the ringgear on. I fortunately had a spare on hand, so I didn't need to use the one that was repaired yet, so I won't be able to testify as to whether or not it is more robust than the original.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 27-02-2011, 19:18
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
why do these always seem to fail? we have a dewalt drill gearbox with exactly the same output method and it supports 400 ft lbs, has anyone considered making a new axle out of harden-able steel?
Unread 27-02-2011, 19:41
Does DeWalt make a 256:1 gear ratio with 400ft-lbs output capability for the same price, size, and weight as a Banebots?
Unread 28-02-2011, 00:40
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
The standard dewalt gear-ratio is about 47:1. And 400 ft-lbs..... well......
But I understand your question was fairly rhetorical ether...
