Go to Post Maybe my brain fog factor has expanded after wading through 1114's competition data sheet, so I cannot see the forest for the trees. - Bill_B [more]
Unread 22-02-2011, 13:46
Larry R Larry R is offline
FRC #1258
Team Role: Electrical
Larry R is on a distinguished road
Send a message via MSN to Larry R
cRIO no longer boots
While reimaging the cRIO to v28, there was what looks like a communication error and aborted.
The error displayed in the Imaging Tool error window:
"Error 60 occured at UDP open in repFPC open connection.vi"
It gave as a possible error that there was another .2 on the network causing a duplicate IP condition. Of course there is only one cRIO and one .2 address.
When I rebooted the cRIO for another attempt, it will not boot up normally.
My question is how do I recover from this problem? The cRIO is unusable. Do I try reimaging in Safe Mode? Did I brick the cRIO?
I found this:
http://www.chiefdelphi.com/forums/ar...p/t-70753.html and see that it is recoverable but I don't need to do an IP reset, I just need to get it to reimage and boot up properly.
Thanks for help.
Further info:
Using a directly connected console, the following is displayed (the cRIO's IP address is still correct):
cRIO-907x Boot
Copyright 2007 National Instruments Corp.
Bootrom version: 2.4.7
Creation date: Jul 9 2007, 00:45:07
Press any key to stop auto-boot...
0
auto-booting...
boot device : tffs=0,0
unit number : 0
processor number : 0
host name : host
file name : /c/ni-rt/system/vxWorks
flags (f) : 0x8
Mounting tffs...
Attaching to TFFS... Datalight Reliance v3.00.1218T
VxWorks Edition for ppc603
Copyright (c) 2003-2007 Datalight, Inc.
done.
Cannot open "/c/ni-rt/system/vxWorks".
Error loading file: errno = 0xd40005.
Booting into Safe Mode from ROM...
Uncompressing kernel...
done.
2910608
Starting at 0x100000...
Mounting tffs...
Entering safe mode.
Initializing network...
Device 1 - MAC address: 00:80:2F:11:50:9E - 10.12.58.2 (primary)
Device 2 - MAC address: 00:80:2F:11:50:9F - 0.0.0.0 (secondary)
