Go to Post "Don't you wish your drill bit was hot like mine?" - BariSaxGuy [more]
Unread 22-02-2011, 14:26
jhellr13 jhellr13 is offline
FRC #4272
jhellr13 is an unknown quantity at this point
servo help
Need help. We want a servo to rotate x amount of degrees when a button is pushed and remain in that position. I have tried multiple ways to program a servo, but can't get it to work right. Diagrams or even attached vis would be greatly appreciated.
Thanks in advance
Unread 28-02-2011, 18:50
Must Be Drama Must Be Drama is offline
Must Be Drama is an unknown quantity at this point
Re: servo help
Thanks in advance
check the servo section in the labview.
theres a set position vi there
all you have to do is put a case structure wired to a button and in the true box put the get servo vi and wire the set postion vi and set what degrees you need
Unread 28-02-2011, 18:56
Re: servo help
Did you install the jumper on the digital sidecar to make sure the servo was powered?
Providing details about what you tried and what exactly it did makes it much easier to help, rather then just stating "everything" you tried "didn't work".
Unread 28-02-2011, 19:01
FRC #4272
Re: servo help
Thanks for the responses. We figured it out. We wanted to use it as a latch for deployment of our minibot. We just rotated the orientation of the servo, so it starts locked like we want, then rotates at a button press for deployment.
