Go to Post I would love access to the crystal ball granting you the insight into these changes. - sdcantrell56 [more]
Unread 22-02-2011, 14:32
Re: Possibly Ruined All Four Jaguars
The black leads are connected to power supply common. There is a layer (maybe two layers) of copper foil that tie all black WAGOs and the negative lead of the battery together. The black leads do not need to come from the same pair but it makes your life and mine a lot easier.
Unread 22-02-2011, 15:56
dekker120 dekker120 is offline
AKA: Matt Mohler
dekker120 is an unknown quantity at this point
Originally Posted by pfreivald View Post
Two years ago we killed two Jaguars doing nothing we could place. After working with the Luminary Micro guy who was on-hand at FLR for over an hour, I finally just said "Switch to Victors. They work!" We did, and they did.
AMEN!!! We didn't blow up any Jaguars last year, but our lifting mechanism kept on tripping the INTERNAL breaker on the Jag... the Snap-action wasn't tripping, just the Jag... So we changed it to a Victor, and didn't have a single problem the rest of the year... We even demoed our bot at the MO State Fair running about 40 matches in 8 hours... victors worked fine... Blew a Jag though!!!
Unread 23-02-2011, 06:22
Matt,
There is no internal breaker on the Jag. There is an over current sense that puts the jag into fault and disables the output for about 3.5 seconds.
