Go to Post When we learn physics, we almost always "ignore friction". The real world never does... - Mike Betts [more]
Unread 22-02-2011, 14:58
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: Updated C-Rio and Labview now code doesnt do ANYTHING
So far it looks like the following have been deemed at least as (probably) not the problem:
-Communications: You were able to enable Teleop, which means that the Communications and Robot Code both show up on the DS.
-Independent of your Joysticks, as the Compressor is not starting.
What I would do:
-Make sure the DSC is connected: 37-pin cable on both ends, Digital Module. 12V,6V, 5V LED's should be on.
-Try running the Default Framework. If you can get Teleop Enabled and your Speed Controller's stop blinking (I don't know which ones are in the Default Framework, you will need to check that and make sure that they are Jaguar/Victor as appropriate) you should be good with your electrical connections, at least with those devices. More importantly that will show that your cRIO firmware image and DS Update are good.
