Go to Post Gotta love it... FIRST's GDC...providing entertainment to loads of bored Bostonian FIRST'ers on a friday night. - Andy Grady [more]
Unread 19-02-2011, 10:17
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Re: Problem with LabView Update 3.2 #2
Originally Posted by Doug Norman View Post
Exactly how are you installing it?
I unzip everything into another folder and I first run the AutoRun and I run the SetUp.
I have done the update for five times and Labview still doesnt run at all.
Unread 19-02-2011, 11:06
Robotheosis Robotheosis is offline
FRC #3135
Robotheosis is an unknown quantity at this point
We extracted it out of the zip file and then ran the application. After re-imaging the cRio it should work. The update came out yesterday.
Unread 22-02-2011, 12:29
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
When the v28 cRIO image came out, we re-imaged our cRIO, and confirmed through the Driver Station. At the time (and currently) our classmate is at LV Update 3.1 The recent Update #12 says that Labview Update 3.2 and cRIO v28 firmware are required. We will be updating our classmate to LV 3.2.
Is there any reason for us to re-image the cRIO with the v28 image that comes with LV 3.2? I do not believe there would be, since I'm sure that the v28 images are the same. I just want to make sure, can one of the NI reps answer this?
Unread 22-02-2011, 12:41
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I don't know what the NI reps will say, but I know when we don't install ALL updates and reimage, things don't go right. Also if the little version number is wrong when the inspectors look at your robot, you'll have to fix it at the regional. We reimaged ours yesterday, it works, it might pass inspection.
Unread 22-02-2011, 13:11
DavidGitz's Avatar
squirrel - Thanks for the response. To clarify, we will have everything updated (the DS and the cRIO) to the most current version at our event. My question is if it will be necessery to re-update the cRIO to v28 after we update the DS to LV 3.2, because the cRIO is already at v28 and the DS is at LV 3.1
Last edited by DavidGitz : 22-02-2011 at 14:04. Reason: put clarification text in separate post
Unread 22-02-2011, 13:25
MrForbes's Avatar
AKA: Jim
what I was hinting at is, when in doubt, reimage. it's not worth the hassle of having to do it later if you can do it now.
Unread 22-02-2011, 14:10
DavidGitz's Avatar
The reason that I'm posting this is because we have already shipped our robot, and trying to avoid any un-needed downtime on our first day at our event. I understand that re-imaging the cRIO is not normally a time consuming process, but sometimes things happen, and I would rather avoid having things happen at an event that do not necessarily* have to happen. It's all about proper risk management. Normally, I would absolutely agree with your comment about "worth the hassle". However, there have been (very rarely) times when re-formatting the cRIO for whatever reason, including a firmware update, resulted in a series of events to happen that resulted in a significant increase in down-time. Some of these reasons include: Ethernet connection comes unplugged, battery dies, computer stops responding, etc. Obviously most of these things can (and are) mitigated as best as possible by proper procedures, communication and extreme diligence. But sometimes things happen, that you cannot control.
Necessarily is obviously the word in question, and since I was not involved with developing the changes and the documentation supplied does not imply that updating the cRIO before the Driver Station is required (as long as the cRIO is at the correct level before-hand) I feel this is a valid question.
Unread 22-02-2011, 14:18
v27 had real changes and a real bug in netconsole that corrupted the stack.
V28 fixed the netconsole bug. I don't know of any other changes. If it is in the bag, don't sweat it.
Greg McKaskle
Unread 22-02-2011, 15:18
I'm still not sure if I know what you're asking. Are you asking if the v28 image from Labview update 3.2 installed from your own computer is the same as the v28 image from LabVIEW update 3.2 installed from the classmate? Or, did you download the pre-release v28 image that Joe Hershberger posted, and want to know if that is the same image that was installed the the LabVIEW update 3.2? Or something else?
Unread 22-02-2011, 22:25
DavidGitz's Avatar
This is what I was asking about, although I assume that the v28 image that was released by Joe Hershberger is no different than the one that is included with LV update 3.2 We updated the cRIO to v28 before LV update 3.2 came out (due to the stack overflow issue and my (incorrect) guess that FIRST would not come out with a mandatory update a week before ship date), then updated the Classmate to LV 3.2, would it be necessary for the FMS or any other reason to re-image the cRIO to v28 (again).
I understand this is confusing, but thanks Greg for the clarification.
Unread 23-02-2011, 13:45
kennethdharmon2 kennethdharmon2 is offline
FRC #1288
kennethdharmon2 is an unknown quantity at this point
We also shipped our robot before seeing update 12. So we will have to reimage at the regional. I think there will be several teams in this predicament.
But just for clarification, the update was for LabView with a new cRIO image. I didn't see anything about a Driver Station software update. Is it necessary to update the classmate? We typically use the classmate only for the Driver Station and use a Laptop for coding and reimaging the cRIO.
Unread 23-02-2011, 14:04
DavidGitz's Avatar
(I believe) It is necessary (generally) if either of the following conditions are true:
-You plan on updating the cRIO firmware with the Classmate or
-You do LabView programming on the Classmate
Unread 27-02-2011, 13:48
edzenitis edzenitis is offline
FRC #2141
edzenitis is an unknown quantity at this point
I have the same problem "unable to open resource files". I ran the update from the extracted file, not the zip file. I have tried to run it two more times and I get the same error.
