Go to Post you know you're going to meet someone important, so you put on your robotics team shirt. - NorviewsVeteran [more]
Unread 22-02-2011, 11:50
pedro123 pedro123 is offline
FRC #3803
pedro123 is an unknown quantity at this point
Code Error (Not getting beyond the loop)
Hi,
So we made a Project with Game Code and added our personal TeleOp code into the designated file. When we try our teleop without uploading the whole project as startup, it works.
However, when I Build the project and Run As Startup and the crio Reboots, only one part of the teleop works. We have compressor code and drive code with two motors plus the pneumatics. When we Run As Startup, our compressor turns on, reaches the limit and stops but we cant control the joystick at all. the error file says that the code is not getting the robotodrive loop. So, I made two while loop with pneumatics and compressor in one and the robotdrive in the other, however it still does not work... Can you help?
Thanks!
Unread 22-02-2011, 13:15
Jimmy the Kidd's Avatar
Jimmy the Kidd Jimmy the Kidd is offline
Programmer, Scouter, Tactician, etc
FRC #0364 (Team Fusion)
Team Role: Tactician
Jimmy the Kidd is an unknown quantity at this point
Re: Code Error (Not getting beyond the loop)
Originally Posted by pedro123 View Post
Hi,
Thanks!
Could you either post the teleop.vi or give a screenshot?
The GDC needs to write the rules once and let the game be what the game is going to be. There's little that's fun about being told exactly how to play with your toys. - Madison
Unread 22-02-2011, 13:43
When you say "try our teleop", what exactly do you mean?
Unread 22-02-2011, 16:14
dekker120 dekker120 is offline
AKA: Matt Mohler
dekker120 is an unknown quantity at this point
Check to make sure that the Watchdog is either Disabled, or that the Watchdog is being "fed" in the while loops... Also check to make sure that the While loops don't have too long of a wait delay... This could be activating the Safety Config feature on the motors. Posting a screenshot would be nice.
Unread 22-02-2011, 21:53
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Read my thread about while loops in teleop. You cant have them in there. You instead can put them into the periodic tasks VI.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 22-02-2011, 22:30
FRC #3803
I will upload a screenshot of my TeleOp vi as soon as possible (most likely tomorrow morning) but till then, I should let you know I have two while loops. I'll update the info tomorrow.
I just read that but my whole teleop code is two while loops, if i place them in the Periodic tasks, do I just leave my teleop code empty (No drive either?) ?
thanks
