Go to Post Besides, you know hard it is to solder with gloves on? - Al Skierkiewicz [more]
Unread 22-02-2011, 16:55
Lucas_bobier Lucas_bobier is offline
FRC #2509
Lucas_bobier is an unknown quantity at this point
Autonomous Code HELP!
Hey everybody,
I was trying to program our autonomous code and i thought we had it but some motors aren't working. they work fine in teleop but in autonomous they don't do anything. Here is a copy of the code, thanks for all your help
Unread 22-02-2011, 17:04
Re: Autonomous Code HELP!
The autonomous VI has a broken run arrow. It has a syntax error. Click on it, read the error message, and see if you can resolve it.
Greg McKaskle
Unread 22-02-2011, 17:07
FRC #2509
Thats for the pneumatics that we just added, that problem is fixed, but the arm motors are still not working
Unread 22-02-2011, 19:11
Look at the Diagnostics of the DS and see what errors are being reported. It looks like at least one solenoid will give an error, then the robot uses only the arm motors for some time, and then only the drive base.
If the name of the motors no longer matches begin, the motor commands have no place to be sent.
Greg McKaskle
