Go to Post my theory on the matter was always something along the lines of "Oh, we're all girls? What an odd thing for you to notice." - karinka13 [more]
Unread 22-02-2011, 18:30
2829ron 2829ron is offline
FRC #2829
2829ron will become famous soon enough2829ron will become famous soon enough
Motor in Autonomous.
Created robot project without game code. Teleop works fine. When I add motors in autonomous they don't run, but the robot will drive. Please help.
Thanx,
David
Unread 22-02-2011, 18:37
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Re: Motor in Autonomous.
I think you need shift registers instead of loop tunnels try that and tell me if it works.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 22-02-2011, 18:41
FRC #2829
Okay. I'll try that. I had tried that on this code before with what I have coded disabled. Does it need to be deleted?
Thanx
David
Unread 22-02-2011, 21:54
FRC #0379
Im not sure what your asking there
Unread 22-02-2011, 22:41
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Here are some "issues", although none of these I don't think are the cause of your problem:
-You should not need shift registers. It is still passing the same reference.
-The +1 in your while loops isn't needed, i is incremented automatically. (unless you want your while loop to run 1 less than the indicated number.
-I would reduce the timer value to less than 50 mS, like 40 or 20. There isn't really any reason to run it longer.
-We like using the express vi "Elapsed Time" instead of looking at the the i value. It is easier to program and I think it's more consistent.
But I think your issue is either in your references (check the Begin and make sure they match) and check if it works in Teleop. If it works in Teleop it is a Programming issue, if not then Electrical.
Unread 23-02-2011, 10:34
FRC #2829
Thanks everyone. Got it to do something with arms and drive motors yesterday (a little more on the drive motors then I wanted ). So I guess I'll code it now and test it at regionals.
Thanx again,
David
