Go to Post If I find a student on my team who came through FIRST having learned nothing more then he wanted to go to MIT, I'll give my self a pat on the back and start counting down to kickoff. - Andy A. [more]
Unread 22-02-2011, 22:45
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Re: No activity on solenoid breakout
Originally Posted by Mark McLeod View Post
Software:
The best test of of the code is to run just the built-in LabVIEW solenoid example accessible from the lower-right corner of the Getting Started screen.
I always suggest running the example code on each element as it is wired onto the board. If the example runs, you know that the wiring is correct. If it doesn't, there aren't very many variables.
Also, look for errors in the diagnostic tab on the DS. I spent some time chasing a similar problem. When I finally looked for error messages, we were getting device reference errors. The real problem was a trailing blank in the name going into the set dev ref that wasn't in the get. Almost impossible to see, it doesn't work, and no broken arrow.
