Go to Post week 7: check to see if the pets are still alive, ask significant others to take us back, do 6 weeks worth of make-up homework, and ask my boss for another extension. - Tim Baird [more]
Unread 22-02-2011, 23:18
Lemonsy Lemonsy is offline
FRC #3028
Lemonsy is an unknown quantity at this point
Java to Labview, using "if else" statements and pressing buttons
I'm originally a java programmer, but I've taken on Labview since this past last year. I'm trying to make a code that will assign a value of 0 when a button ( button 1) is pressed and then change that value into a 1. When the button is then pressed again the value is changed back into a 0.
This code is for a claw that will open and close. Any advice, help, or screenshots?
int x=reader.nextInt(); // takes value of pressing the claw button
while (y==1) //the robot is turned on
if(x==-1)
claw=0; //open position
else(x==0)
claw=1; //close position
x=reader.nextInt(); //checks the next value of the claw button
y=OnOrOff.nextInt() //checks if robot is on or off
Unread 22-02-2011, 23:25
Re: Java to Labview, using "if else" statements and pressing buttons
Here's a button toggle example.
As the example stands the green output alternates between a 1 or 0. You can eliminate the inside Case statement if you don't put anything inside it.
If you want a real number output use "Boolean To (0,1)" located on the boolean palette.
If the claw is solenoid operated you can just stick the activate inside the toggle where indicated and use this in Teleop.
A motor operated claw would require a longer cycle, but could be used, as is, inside Periodic Tasks or Autonomous Independent, not in Teleop.
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
x=reader.nextInt();
claw = !x;
There you go, I optimized it.
Last edited by davidthefat : 22-02-2011 at 23:26. Reason: I forgot x=reader.nextInt();
Unread 23-02-2011, 00:31
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
I'm assuming you know about case structures.
To make an else if statement, you just go to the false case of the case structure and put another case structure inside that.
There are also other ways to do it, like taking all your inputs and making them into a number (with a boolean array to number function, if you're interested) and wiring that one number to the structure. However, it's easiest (although ugliest) to just nest the case structures.
I attached an optimized program for you.
Name:	Program Example.JPG
Unread 24-02-2011, 20:59
FRC #3028
Oh wow, thanks! I've tested both of them, but I need to discuss with my driver and team which they would prefer.
Much appreciated
Unread 24-02-2011, 22:55
frasnow's Avatar
frasnow frasnow is offline
Software
frasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to behold
Originally Posted by Mark McLeod View Post
LabVIEW can certainly make something simple look really complex. I'd be curious to know how long it took to draw that.
Originally Posted by davidthefat View Post
x=reader.nextInt();
claw = !x;.
Simple, easy to read, and can be written in a few seconds. Even when you count the variable declaration.
Unread 25-02-2011, 00:07
I just redrew it in just under a minute.
x=reader.nextInt();
claw = !x;.
Alas, it doesn't do anything like what the original poster wants.
