Go to Post The final product, the inspiration, it all that matters. Awards and championships are just bling. - artdutra04 [more]
Unread 23-02-2011, 01:13
sp33chy sp33chy is offline
FRC #3332
sp33chy is an unknown quantity at this point
Programming disabled function
What would be the legality of the robot slowly retracting its arm while disabled (but on)? Would this be deemed unsafe?
Unread 23-02-2011, 01:27
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: Programming disabled function
If it is in software, absolutely a safety violation. I can't comment on whether or not you CAN do it in software (I'm a hardware guy), but the point of having a disabled robot is that it does not move, and is therefore safe to approach. Robots are disabled when they do something wrong that could break themselves, something else or hurt someone, so under no circumstances do you want a robot that still moves when you disable it, especially under power.
From a mechanical side, there are robots that might move after being disabled due to backdriving motors or pneumatics pressure releases. While not ideal, this can be slightly more safe than software if the devices do not have a lot of energy while moving.
That being said, I would implore you to look into other solutions. Under any circumstance, the best and safest scenario is the robot which doesn't move at all when disabled.
Unread 23-02-2011, 01:33
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
It is impossible to do in software.
You shouldn't worry about it moving. Depending on how your code is written, it might be beneficial to you to write the outputs even while disabled, so you can probe the logic and see what it is doing. That said, when exiting disabled, reset all controllers so it will not move after being enabled, until an input is given.
If it moves while disabled, that is mechanical backdrive.
Kettering Motorsports
