Belt tensioning solution
We undersized the small spocket on our shoulder joint drive and suffered from belt slipping. A quick solution that worked well through our practice rounds was to use Andy Mark's chain tensioner. Just fits over the 15mm Gates belt. We tried these tensioners in 2010 on our drive chains, but they didn't work. They work like a charm on the belt however. We have our fingers crossed that they'll hold up in competition.
Re: Belt tensioning solution
I would use two simple rollers instead.
You could also slot the whole motor mount, so when you need tension you loosen the bolts and pull the whole motor in the direction needed. Then just tighten the bolts again and whala! a nicely tensioned chain or belt. Everyone of my team's wheel, gearbox, and cable mounts is like this and they work perfectly.
I would like to ask the OP on how well the back of those belts slide against that plastic. Is the friction pretty much negligible? Last edited by Thermal : 23-02-2011 at 01:49. |
By the way, we have slots in our shaft mounts, but we were not able to get enough tension in both sides of this long belt that way. |
You could try a floating idler as well. See: http://www.team228.org/media/pictures/view/5117
I've never seen them on a timing belt before, but I suspect they would work as long as you get enough tooth engagement to make sure they don't fall out. |
#7
