Go to Post I wonder if the kit motors run counterclockwise in the Southern Hemisphere? - Gary Dillard [more]
Unread 12-02-2011, 15:22
LK Peter LK Peter is offline
FRC #3871
LK Peter is an unknown quantity at this point
Exclamation how do you make 2 joysticks run 4 motors on labview
does anyone have a plot of how to make two joysticks run four motors for labveiw because my team is trying to do that but we can only get one of the joysticks working.
Unread 12-02-2011, 20:03
PatrickS's Avatar
PatrickS PatrickS is offline
I get my code from /dev/null
FRC #1742 (Shockwave)
PatrickS is an unknown quantity at this point
Re: how do you make 2 joysticks run 4 motors on labview
In your Begin.vi use the open 4 motors instead of open 2 motors. You will also need to open up another joystick. Then in your Teleop.vi instead of using ArcadeDrive.vi use TankDrive.vi and link it to your open 4 motors you initialized in Begin.vi. Then plug in the two joysticks and you should be good to go.
Remember to close everything in Finish.vi.
Make sure you make use of the examples they provide. Here is the TankDrive example:
Unread 13-02-2011, 11:47
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Use the PWM Y-cables in the KOP
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 23-02-2011, 08:17
Nicandy's Avatar
Nicandy Nicandy is offline
AKA: Nicole/Andy
FRC #3580 (Marinerds)
Nicandy is an unknown quantity at this point
Can you re-upload that picture? It seems to be broken.
Unread 23-02-2011, 08:33
Nicandy's Avatar
AKA: Nicole/Andy
Is that in the Begin.vi or in the teleop.vi?
Unread 23-02-2011, 09:40
Here's a similar Tank Drive example.
Unread 23-02-2011, 11:12
As a general rule:
Opens go in Begin. Gets and Sets and Drives go in Teleop. Closes go in Finish.
Read the LabVIEW tutorial on how to integrate examples into a robot project.
