Go to Post Naw, basketball isn't nearly as great a sport as FRC. They play for the money. We play for honor, dignity, and respect. - synth3tk [more]
Unread 20-02-2011, 21:58
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
pic: Chain tension
Unread 20-02-2011, 22:00
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: pic: Chain tension
Very nice! far more professional looking than ours....
Unread 21-02-2011, 01:44
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
nice, we will probably try to integrate something like that in our robot next year, this year we have floating rings one one chain, and a regular tensioned with some shims as the chain stretches on the other.
Unread 21-02-2011, 09:50
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
I like using PVC too, though it tends to get chewed up a bit, and might need to be flipped before eliminations
Unread 21-02-2011, 09:57
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
We have used 1" diameter UHMW we cut flats in the ends and bolt it to the chassis. This even works well for high load components, such as arms and such.
I will see if i can get a picture soon.
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 21-02-2011, 11:03
bmxer51 bmxer51 is offline
FRC #2874
bmxer51 is an unknown quantity at this point
This is a great idea! I have been trying to come up with a better way than moving the gearboxes back and forth but my search has ended! Thank you!
Unread 23-02-2011, 11:33
joeweber's Avatar
Coach team 1322
We are using it on our belt drive system, it works great for fine tuning and alignment. I think it would work well with chains also. It is so easy to use, we pop off the bupers and inset a deep socket and adjust it. We did have to add a threaded hole at the ends of the axle to remove the shaft out the side of the frame. With all the items covering the axel you can't get a hold of it so we thread in a screw and pull it out easy.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
